Dyno results of a tuned Ls/Vtec OEM parts build.
Old Apr 3, 2005 | 10:02 PM
mtber's Avatar
Default Dyno results of a tuned Ls/Vtec OEM parts build.
I built & tuned this motor for a friend.
I decided to post the results to show/confirm what a setup like this can do.
Note: The sniffer/wideband wasnt reading partial throttle very well, hence the wierd throttle tip in. Futhermore, this run was not the last run. I printed this run due to heatsoak at run 23 within 1.5 hours. A/F ended up at 13.2-13.5ish at the last run according to the sniffer which was being a little iffy.
Specs are:
Ls/Vtec specs estimated 12.3:1 estimated compression ratio
B18a1 block/rods/crank
Arp rod bolts
CTR .25 over pistons
Ls headgasket
Brand New 2001 ITR head & cams
AEBS intake manifold & a 65mm throttle body
Skunk2 Cam Gears
Golden eagle lsvtec line kit & dowels
Chipped ecu running a custom program.
Exedy clutch w/ oem b16 flywheel
2000 b16 transmission
B&m fpr set at 51 psi & guage
AEM intake
Powersteering bypassed
JDM itr header & Greddy Evo Exhaust with a highflow resignator
Tuned by John Vega - Phearable.net on Crome Pro.
- John Vega
Old Apr 3, 2005 | 10:04 PM
GUILOTINE's Avatar
Kill Gil
seems pretty low, or is it just me?
Old Apr 3, 2005 | 10:15 PM
mtber's Avatar
Default Re: (GUILOTINE)
<TABLE WIDTH="90%" CELLSPACING=0 CELLPADDING=0 ALIGN=CENTER><TR><TD>Quote, originally posted by GUILOTINE &raquo;</TD></TR><TR><TD CLASS="quote">seems pretty low, or is it just me?</TD></TR></TABLE>
185 whp and 134 tq is low ?
I had a simular setup, except using jdm itr pistons with a c/r of 11.6:1 c/r made 184whp and 134 tq
The numbers are average for this setup.
Combustion Contraption's Avatar
185hp, 135tq, thats great for a mostly OEM build!
I bet the rings havent even finished seating....
Old Apr 3, 2005 | 10:17 PM
mtber's Avatar
Default Re: (LsVtec92Hatch)
<TABLE WIDTH="90%" CELLSPACING=0 CELLPADDING=0 ALIGN=CENTER><TR><TD>Quote, originally posted by LsVtec92Hatch &raquo;</TD></TR><TR><TD CLASS="quote">185hp, 135tq, thats great for a mostly OEM build!
I bet the rings havent even finished seating....</TD></TR></TABLE>
Rings seat quicker then you think :-)
Old Apr 3, 2005 | 10:28 PM
5STAR3's Avatar
Default Re: (mtber)
Old Apr 3, 2005 | 11:30 PM
sheepey's Avatar
very nice numbers
Old Apr 3, 2005 | 11:33 PM
Greenery18's Avatar
Default Re: (envision2teg)
Awesome build
I am looking to build an almost identical setup, using all Honda parts. Looking at other setups with CTR slugs and ITR cams, you could be making 10 or 15 more horsepower...maybe.
Old Apr 3, 2005 | 11:46 PM
mtber's Avatar
Default Re: (Greenery18)
<TABLE WIDTH="90%" CELLSPACING=0 CELLPADDING=0 ALIGN=CENTER><TR><TD>Quote, originally posted by Greenery18 &raquo;</TD></TR><TR><TD CLASS="quote">Awesome build
I am looking to build an almost identical setup, using all Honda parts. Looking at other setups with CTR slugs and ITR cams, you could be making 10 or 15 more horsepower...maybe.</TD></TR></TABLE>
This isnt my motor. I am just the tuner & builder.
Personally, from a tuner/builder standpoint I wouldnt expect more then mid to high 180s for this setup.
The setups I have seen in person that were identical put down less whp.
One did 179 whp & 132 tq and another did 186 whp and 133 tq.
I have yet to see another motor with this same exact setup make drastically better numbers.
Feel free to post your dyno results when your setup is done to compare the setups.
Old Apr 4, 2005 | 12:02 AM
butters's Avatar
Default Re: (mtber)
<TABLE WIDTH="90%" CELLSPACING=0 CELLPADDING=0 ALIGN=CENTER><TR><TD>Quote, originally posted by mtber &raquo;</TD></TR><TR><TD CLASS="quote">
The numbers are average for this setup.</TD></TR></TABLE>
i agree. i'd say those numbers look dead on with using itr cams. There's def. more room for power if bigger cams, better header and more tuning. good job overall though
Old Apr 4, 2005 | 12:27 AM
Greenery18's Avatar
Default Re: (butters)
I was comparing to a dyno like this one:
Old Apr 4, 2005 | 12:32 AM
mtber's Avatar
<TABLE WIDTH="90%" CELLSPACING=0 CELLPADDING=0 ALIGN=CENTER><TR><TD>Quote, originally posted by Greenery18 &raquo;</TD></TR><TR><TD CLASS="quote">I was comparing to a dyno like this one:
I call bullshit on that dyno chart.... 145 peak tq on a 1.8L using ctr pistons.
I would have to see it in person.
Old Apr 4, 2005 | 12:33 AM
mtber's Avatar
Image didnt load...
Direct link: http://www.importreview.com/dy...2.gif
Old Apr 4, 2005 | 02:23 AM
1999all_motoR_teg's Avatar
Default Re: (mtber)
Nice numbers. Does anyone know what that would be corrected??
Old Apr 4, 2005 | 08:29 AM
ea_hatch's Avatar
Default Re: (1999all_motoR_teg)
LS V-TEC set-up
81mm
CTR pistons
CTR intake cam
DC header
cam gears
fpr
V-AFC
12.47@106 MPH (ALL MOTOR)
http://www.humbleperformance.com/ea_hatch/ef.wmv
Old Apr 4, 2005 | 08:44 AM
mtber's Avatar
<TABLE WIDTH="90%" CELLSPACING=0 CELLPADDING=0 ALIGN=CENTER><TR><TD>Quote, originally posted by 1999all_motoR_teg &raquo;</TD></TR><TR><TD CLASS="quote">Nice numbers. Does anyone know what that would be corrected?? </TD></TR></TABLE>
SAE corrected it would be 184 peak whp instead of 185.9
Old Apr 4, 2005 | 08:49 AM
mtber's Avatar
Default Re: (ea_hatch)
<TABLE WIDTH="90%" CELLSPACING=0 CELLPADDING=0 ALIGN=CENTER><TR><TD>Quote, originally posted by ea_hatch &raquo;</TD></TR><TR><TD CLASS="quote">
LS V-TEC set-up
81mm
CTR pistons
CTR intake cam
DC header
cam gears
fpr
V-AFC
http://www.humbleperformance.com/ea_hatch/ef.wmv</TD></TR></TABLE>
Again, I would have to see the setup in person on a dyno I use. I don't believe in 145 peak tq on a 1.8L ls/vtec using ctr slugs :-) Especially after seeing as many cars I have seen on the rollers with built 1.8L setups using oem & aftermarket parts etc.
I am not trying to suggest your motor isnt doing those numbers. I just find it hard to believe :-)
Old Apr 4, 2005 | 09:05 AM
DDD's Avatar
DDD
Default Re: (mtber)
LS V-TEC set-up
81mm
CTR pistons
CTR intake cam
DC header
cam gears
fpr
V-AFC
What ECU is running this? Also do you drive it on pump gas?
to all the setups
Old Apr 4, 2005 | 09:33 AM
ea_hatch's Avatar
Default Re: (DDD)
<TABLE WIDTH="90%" CELLSPACING=0 CELLPADDING=0 ALIGN=CENTER><TR><TD>Quote, originally posted by DDD &raquo;</TD></TR><TR><TD CLASS="quote">
to all the setups</TD></TR></TABLE>
PWO w/ MUGEN program. It was dynoed w/ 100+ octane.
Old Apr 4, 2005 | 12:12 PM
AnToNy's Avatar
Default Re: Dyno results of a tuned Ls/Vtec OEM parts build. (mtber)
Good #s, I would like to make around 190 when I do my build this summer.
Old Apr 4, 2005 | 12:17 PM
boosted k20's Avatar
Default Re: Dyno results of a tuned Ls/Vtec OEM parts build. (jaedaSC)
the a/f ratios were in the 13.2-13.5? it looks a little bit lean after 7K to 8K. when i tune i try to get a/f in the 13.0 just for an extra safety. but anyways, great number!
Old Apr 4, 2005 | 12:35 PM
Professor15's Avatar
Nice numbers....like you stated average. But there is definatly room for improvement with other mods.
Old Apr 4, 2005 | 12:59 PM
ThatsMyEG's Avatar
Default Re: (drchulo)
maybe you should do hondata
Old Apr 4, 2005 | 01:48 PM
mtber's Avatar
Default Re: Dyno results of a tuned Ls/Vtec OEM parts build. (boosted k20)
<TABLE WIDTH="90%" CELLSPACING=0 CELLPADDING=0 ALIGN=CENTER><TR><TD>Quote, originally posted by boosted k20 &raquo;</TD></TR><TR><TD CLASS="quote">the a/f ratios were in the 13.2-13.5? it looks a little bit lean after 7K to 8K. when i tune i try to get a/f in the 13.0 just for an extra safety. but anyways, great number!</TD></TR></TABLE>
Note: The sniffer/wideband wasnt reading partial throttle very well, hence the wierd throttle tip in. <U> Futhermore, this run was not the last run. I printed this run due to heatsoak at run 23 within 1.5 hours. A/F ended up at 13.2-13.5ish at the last run according to the sniffer which was being a little iffy.
</U>
mtber's Avatar
Default Re: (ThatsMyEG)
<TABLE WIDTH="90%" CELLSPACING=0 CELLPADDING=0 ALIGN=CENTER><TR><TD>Quote, originally posted by ThatsMyEG &raquo;</TD></TR><TR><TD CLASS="quote">maybe you should do hondata</TD></TR></TABLE>
I think you should get a clue
Tune a car on crome, tune it on hondata and tune it on aem ems.
They will all make the same power in the end.
