00-01 GSR = 2 o2 sensors + obd1 conversion = only 1 o2 sensor needed?
Old Apr 3, 2005 | 08:34 PM
Integgin's Avatar
Default 00-01 GSR = 2 o2 sensors + obd1 conversion = only 1 o2 sensor needed?
The above statement might be confusin
i have a 2000 gsr...there is one o2 sensor on the header and one o2 sensor on the cat...making it 2 o2 sensors...am i correct?
if you answered yes above...heres my next question...if i do a obd2b to obd1 conversion....does the o2 sensor on the header have to be installed? or can i leave it off? thats my main question..
Otherwise..do you guys think the conversion is a good mod if i get a good price on the ecu and harness? Thanks
Old Apr 3, 2005 | 09:00 PM
tub_sephiroth's Avatar
Default Re: 00-01 GSR = 2 o2 sensors + obd1 conversion = only 1 o2 sensor needed? (Integgin)
I believe you keep the one on the header because that's the primary, you remove the one on the cat. That's the secondary.
Old Apr 4, 2005 | 03:08 PM
rovigian's Avatar
Default Re: 00-01 GSR = 2 o2 sensors + obd1 conversion = only 1 o2 sensor needed? (tub_sephiroth)
<TABLE WIDTH="90%" CELLSPACING=0 CELLPADDING=0 ALIGN=CENTER><TR><TD>Quote, originally posted by tub_sephiroth &raquo;</TD></TR><TR><TD CLASS="quote">I believe you keep the one on the header because that's the primary, you remove the one on the cat. That's the secondary.</TD></TR></TABLE>
Keep the one in the header. The one in the cat doesn't have to be removed, you can just keep it there and the OBD1 ecu will ignore it.
crxb18ls
25
Oct 18, 2007 07:01 PM
RidingMark
Mar 3, 2007 08:14 AM
1SlowSi
Jan 31, 2005 09:13 PM
colombian linx
Feb 3, 2004 08:57 AM
964dgsr
Sep 25, 2003 07:53 AM
