Where do these go in my tranny???
<FONT SIZE="18">EDIT: Its a hydro B-series LS tranny</FONT>
Yes, that is my transmission. Yes, it is open. Yes, those came out of it. Where they go? We dont remember. Hopefully, you do. If you can identify those and tell me where they go, Ill be your best friend.
We had to swap cases because the one the tranny came in was cracked.
http://img166.exs.cx/img166/8871/trans4ls.jpg
http://img233.exs.cx/img233/8875/trans39we.jpg
looks like shims, probably for differential. BTW, you'll need to check the clearance between the diff bearing and case, then order a new shim from honda so that the clearance is between 0 to 0.2mm.
