Where do these little thingies go???
Old Apr 3, 2005 | 07:15 PM
UrbanFuturistic's Avatar
Default Where do these little thingies go???
<FONT SIZE="18">EDIT: Its a hydro B-series LS tranny</FONT>
Yes, that is my transmission. Yes, it is open. Yes, those came out of it. Where they go? We dont remember. Hopefully, you do. If you can identify those and tell me where they go, Ill be your best friend.
We had to swap cases because the one the tranny came in was cracked.
http://img166.exs.cx/img166/8871/trans4ls.jpg
http://img233.exs.cx/img233/8875/trans39we.jpg
Old Apr 3, 2005 | 07:24 PM
drdisco69's Avatar
Default Re: Where do these little thingies go??? (UrbanFuturistic)
With all you guys giving each other the shocker, it's a wonder you get anything done around there.
Bump for this guy.
Old Apr 3, 2005 | 07:46 PM
hondaguyef's Avatar
Default Re: Where do these little thingies go??? (drdisco69)
Two of those little thingies goes in the pink and the other goes in the stink . J/K I am not a tranny guru and have no idea where those go.
Phil
Old Apr 3, 2005 | 08:11 PM
W C L's Avatar
one is a spring wahser and the other is a reg washer.... they lay on the bearing in the case between the shaft with 3rd-4th and 5th....
spring washer on the bottom and regular washer ontop
Old Apr 3, 2005 | 08:37 PM
Jim Truett's Avatar
Default Re: (Big Will)
<TABLE WIDTH="90%" CELLSPACING=0 CELLPADDING=0 ALIGN=CENTER><TR><TD>Quote, originally posted by Big Will &raquo;</TD></TR><TR><TD CLASS="quote">one is a spring wahser and the other is a reg washer.... they lay on the bearing in the case between the shaft with 3rd-4th and 5th....
spring washer on the bottom and regular washer ontop</TD></TR></TABLE>
You sure about that?
They look like the spring and shim washers that go between the ISB and mainshaft first gear.
Old Apr 3, 2005 | 09:07 PM
W C L's Avatar
Default Re: (Jim Truett)
<TABLE WIDTH="90%" CELLSPACING=0 CELLPADDING=0 ALIGN=CENTER><TR><TD>Quote, originally posted by Jim Truett &raquo;</TD></TR><TR><TD CLASS="quote">
They look like the spring and shim washers that go between the ISB and mainshaft first gear.</TD></TR></TABLE>
im positive
Old Apr 3, 2005 | 09:17 PM
jordan's Avatar
they were to small to fit there. they fit perfect on top of the bearing where the input shaft is. i still don't think thats where they go though.
*edit* just looked at a diagram we put them in the right place.
Old Apr 4, 2005 | 12:38 AM
SJcivic's Avatar
Default Re: (jordan)
those look like thrust bearing shims...
Rich
Old Apr 4, 2005 | 01:04 AM
SlowReaction's Avatar
Default Re: (SJcivic)
Those slide onto the mainshaft before you put the gear stacks back into the housing. The flat washer slides on first then the spring washer goes on after. For the spring washer, the inner circle must face the housing side. Didnt really know how to word that but I think you get the idea.
Old Apr 4, 2005 | 06:06 AM
tgreaves's Avatar
Default Re: (SlowReaction)
<TABLE WIDTH="90%" CELLSPACING=0 CELLPADDING=0 ALIGN=CENTER><TR><TD>Quote, originally posted by SlowReaction &raquo;</TD></TR><TR><TD CLASS="quote">Those slide onto the mainshaft before you put the gear stacks back into the housing. The flat washer slides on first then the spring washer goes on after. For the spring washer, the inner circle must face the housing side. Didnt really know how to word that but I think you get the idea.</TD></TR></TABLE>
Just dont get them backwards or your tranny will bind up when you bolt the case all back together, trust me I know..
Old Apr 4, 2005 | 06:10 AM
IN VTEC's Avatar
The order goes clutch housing - input shaft seal - input shaft bearing - spring washer (concave side faces up towards the gears) - washer - mainshaft gearset.
qweakers
Jan 7, 2012 10:27 AM
swatteamtimmah
Mar 18, 2006 12:27 PM
UrbanFuturistic
Apr 11, 2005 07:46 PM
btleier
Oct 6, 2003 06:18 PM
