spark plugs.. lean ??
Is it just me or does the center of the spark plug on the first pic look melted or slotted or something abnormal.
The color doesn't look terrible. Go rip on it through a few gears then immediately pull them out and show us what they look like.
ls/vtec 11.6:1 compression. intake, stock gsr header ctr cams...ive gotten on it a few times and drove over 600 miles in the last two days... i put the plugs in two days ago.
<TABLE WIDTH="90%" CELLSPACING=0 CELLPADDING=0 ALIGN=CENTER><TR><TD>Quote, originally posted by asubennett »</TD></TR><TR><TD CLASS="quote">Is it just me or does the center of the spark plug on the first pic look melted or slotted</TD></TR></TABLE>
yah they are the NGK v-power plugs
Oh ok that makes sense. Looking at the plugs I don't think you are running terribly lean. There are no white spots or flaking. The top of the plug still looks black. Everything is still intact.
If stock ignition I would stick with .034</TD></TR></TABLE>
Damn, no ****? I've always gapped mine at .40-.42
A wider gap will burn the mixture more efficiently if you have a hot enough ignition to jump that wide gap properly. In my experience I think .034-.036 is the most I would go with stock ignition.
PLEASE put some Anti-Seize on those plugs! Please do it for me! I always use anti-seize on my plugs, also try NGK plug R5671A-8, you could probably even go with the 7s with your CR.
<TABLE WIDTH="90%" CELLSPACING=0 CELLPADDING=0 ALIGN=CENTER><TR><TD>Quote, originally posted by LSVTEC 91 Civic »</TD></TR><TR><TD CLASS="quote"> Damn, no ****? I've always gapped mine at .40-.42</TD></TR></TABLE>
You know that plug works
Dartanian
May 13, 2006 05:26 AM
