Best Way to Fix a Broken Lip?
if you really want it you could fiber glass it together.. either go to a body shop or do it urself but, if you want inexpensive work u'd be better off superglueing it just don't plan on keeping it too long
ok if its split in two. use FIBERGLASS. to use fiber glass. its comes in sheets. and you have to buy RESIN and HARDNER. get the fiberglass sheet. cut out the amount you need. put it on a cardboard, and spread the RESIN onto it. before spreading resin. add the hardner to the resin. spread until the fiberglass is soaked. then apply the fiberglass to your lip the outside and inside. use about 5 layers of fiberglass. and get ready to do some major sanding! thats how i would do it!
yea its filler but its strong enough to hold that lip together, and will also last. its kind of hard to work with because it gets hard very fast. it will also work way better than super glue
SovXietday
Jan 1, 2006 10:13 AM
