People who have done the ITR caliper upgrade on your 4x100 check this out...
Old Apr 3, 2005 | 01:26 PM
SilverDc2's Avatar
Default People who have done the ITR caliper upgrade on your 4x100 check this out...
lately i've been waiting to upgrade to the itr caliper because of the bigger pad/brakes....
i dont need instructions, but i do need feedback on how your brake feel is...
How is your brake pedal compared to stock, did it spongy softer?
i ask this because on my friend 00 si we installed a 5lug and his M/C went out, got a new one his brake pedal isn't that great pretty soft....
just wondering if you want a hard pedal do you need to upgrade to a itr m/c change the prop valve which one..?
thanx
Old Apr 3, 2005 | 01:40 PM
non-VTEC's Avatar
Default Re: People who have done the ITR caliper upgrade on your 4x100 check this out... (SilverDc2)
i just got finished doing a front and rear ITR caliper upgrade to my 95 integra RS a few weeks ago.
the brake pedal is "slighty" softer than how it was before but not bad enough that its not drivable or dangerous........maybe i just need to bleed it a little better. but other than that the braking is incredible.
you should try re-bleeding the brake system on your freinds car and maybe that will stiffen the pedal up a little more. if that doesnt solve the problem you might need to upgrade to a integra 1" master cylinder. or that master cylinder you guys put on is no good.
but i'd like to note that my 15/16" master cylinder seems to be working perfectly fine like i said before.
Old Apr 3, 2005 | 04:15 PM
ctownintegra's Avatar
Are you guys just swapping the calipers or the entire 5 lug? If just the calipers then I want to know how.
Old Apr 3, 2005 | 06:04 PM
non-VTEC's Avatar
Default Re: (ctownintegra)
<TABLE WIDTH="90%" CELLSPACING=0 CELLPADDING=0 ALIGN=CENTER><TR><TD>Quote, originally posted by ctownintegra &raquo;</TD></TR><TR><TD CLASS="quote">Are you guys just swapping the calipers or the entire 5 lug? If just the calipers then I want to know how.</TD></TR></TABLE>
https://honda-tech.com/zerothread?id=734560&page=1
no1else
Honda CR-V & Element
Jun 23, 2013 03:32 PM
1 sicK gtR33
Suspension & Brakes
May 19, 2010 02:49 AM
Project X
Oct 7, 2004 01:13 PM
an2ny888
Oct 8, 2003 08:05 PM
