timing belt
Old Apr 3, 2005 | 12:36 PM
VINtegra90's Avatar
Default timing belt
the car i bought didnt come with any service records so how can i check to see that my timing belts alright
i hear theres some bad consequences if it breaks
Old Apr 3, 2005 | 12:37 PM
numbnuts22715's Avatar
just change it around 80-90 thousand miles or so and it should be fine.
Old Apr 3, 2005 | 01:15 PM
sabotage7's Avatar
Default Re:
how many miles does it have on it? i would probably just change it if i were you just to be safe if you're not sure when/if it was done. one thing i did, was i called around the local dealers and gave them my VIN and told them i just purchased the vehicle and wanted all the service records. now, this would only work if the vehicle is dealer maintained of course, which mine was. the guy that had the car before me said that he had the timing done, but i wanted to make sure, so i called around and had all the info on my car faxed to me and found that it was done. it made me feel better anyways! so, if you know where the vehicle was serviced, you may be able to do that. good luck!
Old Apr 3, 2005 | 01:22 PM
nutchee's Avatar
European service of timing belt is 100.000km.. about 60.000miles
Old Apr 3, 2005 | 01:53 PM
Finger Lickin' good's Avatar
Default Re: (nutchee)
just remove the valve cover. If its really bad youll see cracking on the inside teeth.
Old Apr 3, 2005 | 05:26 PM
VINtegra90's Avatar
Default Re: (D-CeReaL#4)
alright thanks guys.. and r the belts expensive?
Old Apr 3, 2005 | 05:39 PM
blkb18's Avatar
Default Re: (VINtegra91)
parts are 35-45 for the belt, 45-60 for the water pump if needed.
Old Apr 3, 2005 | 06:00 PM
VINtegra90's Avatar
Default Re: (blkb18)
hey not bad .. thanks people
Old Apr 3, 2005 | 07:02 PM
virusiidx's Avatar
<TABLE WIDTH="90%" CELLSPACING=0 CELLPADDING=0 ALIGN=CENTER><TR><TD>Quote, originally posted by D-CeReaL#4 &raquo;</TD></TR><TR><TD CLASS="quote">just remove the valve cover. If its really bad youll see cracking on the inside teeth. </TD></TR></TABLE>
yeah pretty much what he said if you wanna just check how it's doing.
msnewman
Jul 19, 2012 05:13 AM
mailman1
Jan 7, 2011 06:05 PM
AnAccordIsForever
Mar 12, 2007 02:55 PM
Campee
May 4, 2005 10:05 AM
andrekun
Oct 29, 2001 12:43 PM
