wtf?!?! steering wheel hub wont go on!!!
Hey I just got this new steering wheel hub/quick release thing and i cant get it to slide on for the life of me. I removed my old steering wheel(stock) but then when i tried to slide the new hub onto the spline it just would slide on, like it was too small or something, it seemed very close but wouldnt go. I still have the SRS plate or whatever on, do i need to remove that? Should i put some oil on the new hub would that help?
Very confused/frustrated, this hub is supposed to fit 92-95 civics.....
Help!
Help!
its easy, you just undo the wire harness and it should slide off, or maybe it did have screws, either way it was so easy I can't even remember. Play with it a bit and look around, you'll find it. Ironnically i need one now so if you wanted to sell me yours when you get it of let me know.
ah got it, damn working in the dark! Working by flashlight i missed the bolts holding it on.
Got it all set now, 350mm is much better than whatever stock is
pm me if you still need that!
RGuo921
Sep 16, 2008 09:39 PM
Sijray21
Feb 28, 2006 08:33 AM
metalgears
Jul 25, 2004 12:08 PM
