Suspension & Brakes Theory, alignment, spring rates....
Comptech Sway/Tie Combo: What Setting are you running (Hard, Medium, or Soft)?!
Old Apr 3, 2005 | 12:16 PM
xpLicit bLu's Avatar
Default Comptech Sway/Tie Combo: What Setting are you running (Hard, Medium, or Soft)?!
Hey guys,
Just trying to see what position you guys are running on your comptech swaybars. Also, I think itd be helpful if you guys list what your suspension set up is as well. I'm trying to find a nuetral setup for my car... Your input would be great!
Im running GC 400F 300R w/ Konis w/ my Comptech sway/tie on the softest setting .
Old Apr 3, 2005 | 01:15 PM
95LSDOHC's Avatar
Default Re: Comptech Sway/Tie Combo: What Setting are you running (Hard, Medium, or Soft)?! (xpLicit bLu)
i run mine on the hard setting 24/7...its the best one
Old Apr 3, 2005 | 02:31 PM
slammed_93_hatch's Avatar
Default Re: Comptech Sway/Tie Combo: What Setting are you running (95LSDOHC)
ya you will need it on full stiff
Old Apr 3, 2005 | 02:40 PM
Default Re: Comptech Sway/Tie Combo: What Setting are you running (slammed_93_hatch)
do you guys get any snap oversteer... how is it in the rain on full stiff?
Old Apr 3, 2005 | 02:50 PM
95LSDOHC's Avatar
Default Re: Comptech Sway/Tie Combo: What Setting are you running (xpLicit bLu)
to be honest...i went from stock sway w/ lowering springs on stock shocks.....to tein flex and the comptech sway/tie combo....so its kinda hard for me to tell you what its like since i only know shitty and really stiff
so far i feel it does great in the rain...maybe somebody else has a better explaination
Old Apr 3, 2005 | 02:59 PM
travis's Avatar
<TABLE WIDTH="90%" CELLSPACING=0 CELLPADDING=0 ALIGN=CENTER><TR><TD>Quote, originally posted by xpLicit bLu &raquo;</TD></TR><TR><TD CLASS="quote">do you guys get any snap oversteer... how is it in the rain on full stiff?</TD></TR></TABLE>
You generally want to run a softer setup in the rain compared to what you find you like in the dry.
What's wrong with good 'old trial n' error? It takes 5 minutes to change the setting.
Old Apr 3, 2005 | 03:02 PM
Default Re: Comptech Sway/Tie Combo: What Setting are you running (travis)
<TABLE WIDTH="90%" CELLSPACING=0 CELLPADDING=0 ALIGN=CENTER><TR><TD>Quote, originally posted by travis &raquo;</TD></TR><TR><TD CLASS="quote">What's wrong with good 'old trial n' error? It takes 5 minutes to change the setting.</TD></TR></TABLE>
I probably will end up just trying out all the settings... but, just wanted to hear other peoples opinions.
Old Apr 3, 2005 | 07:47 PM
travis's Avatar
I probably will end up just trying out all the settings... but, just wanted to hear other peoples opinions.</TD></TR></TABLE>
That's what I would do. Unless you're talking to someone with the same car, the same suspension setup, the same alignment, everything...their opinion isn't really all that helpful. And even in the same car, your preference for your driving technique might vary. Just get out there and do some testing and let us know what you think.
JDMGSRCRX
Nov 16, 2005 07:22 AM
FireMedic
Mar 19, 2004 07:43 PM
gakkuken
16
Dec 22, 2003 02:10 PM
tampaSi
17
Jan 24, 2002 06:30 AM
