ITR rear trailing arm same as GSR or LS?
I have a 5 lug conversion on my coupe...and I believe my right rear trailing arm is bent. Just wondering if anyone knows whether the trailing arm is the same as a GSR or LS so I can get ont to replace it. I also put this in the ITR forum.
i had the same problem.. i had to use a gsr rear trailing arm.. they are the same except for the BUSHING.. the ITR busing is slightly stiffer... i was wardned about this but when i put it on i couldnt tell a difference... but i never tracked my car so i wouldnt be able to tel probably.. normaly eveyr day it rode just fine.. so the answer yes the actual trailing arm is the same..
there are some who say that the jdm ITR and CRT rear trailing arms are slightly wider although they still bolt up no problem
the_illest_soldier
Apr 3, 2005 10:28 PM
