High idle when cold (searched)
Old Apr 3, 2005 | 11:37 AM
LShatchie's Avatar
Default High idle when cold (searched)
My idle on my b18a seems kinda high when its cold, 2100-2300 rpms, but when it warms up its perfect, around 800-900 rpms. Does anyone know what could be going on? Also I have a brand new FITV so that cant be the problem.
Old Apr 3, 2005 | 11:40 AM
virusiidx's Avatar
normal idle should be around 750+- 50, try adjusting the idle screw a little lower. 2000rpm cold start doesnt sound bad.
Old Apr 3, 2005 | 11:41 AM
integrals98's Avatar
Default Re: High idle when cold (LShatchie)
thats normal, if your car idle at 800rpm when cold then you have a problem.
Old Apr 3, 2005 | 11:44 AM
LShatchie's Avatar
Default Re: (virusiidx)
I tried adjusting the screw and when it warmed up it was around 700 rpms and it seemed so low that it was going to stall, ill try it again. Maybe im just thinking its really high because even though its at 2000rpms cold it just sounds really loud because of my exhaust.
I just thought it was a high idle because I read most people had their cold idle around 1300-1500 rpms
Old Apr 3, 2005 | 12:33 PM
VINtegra90's Avatar
Default Re: (LShatchie)
i think its all normal.. my car does it too
the engine probably works harder to warm itself up --> higher revs
when its already hot --> revs low
just like when u put ur foot on ur power brakes or turn on ur a/c... --> higher revs
Old Apr 3, 2005 | 01:50 PM
non-VTEC's Avatar
it could probably be that IACV going bad...........i would not really worry to much about it though.....as long as it warms up and idles like normal it should be fine.
Old Apr 3, 2005 | 01:56 PM
Finger Lickin' good's Avatar
Default Re: High idle when cold (non-VTEC)
your cars getting old, needs a little more help warming up. nothing to worry about.
Old Apr 3, 2005 | 04:40 PM
ebpda9's Avatar
Cpt Rice
that's pretty normal, and the winter that northeast had this year no wonder it does that.
PhilMac
Jan 15, 2008 07:02 PM
TheNasty0ne
Dec 17, 2005 01:07 PM
jokr78
Dec 15, 2004 01:47 PM
