26 spline axle wont go into 26 spline tranny
Old Apr 3, 2005 | 10:58 AM
crxzcracer's Avatar
From: Murfreesboro, Tennessee, United States of America
Default 26 spline axle wont go into 26 spline tranny
H-t you have got to help me this is the only thing stopping me from having my car back!!!
i have 91 crx with a 91 si tranny and a 90 si axle
the axle goes half way in and just stops i have hit it and pushed and pull and yelled i have tired it all any suggestions?
when i feel the inside of the tranny after the splines there is a bar that goes like \ between the axles? is that right?
I had a 91 hf axle in the tranny for a long time is there a dif. in the 91 hf crx and the 90 si civic axle?
Old Apr 3, 2005 | 11:02 AM
mr. carpenter's Avatar
Default Re: 26 spline axle wont go into 26 spline tranny (crxzcracer)
spline count only matters on the outboard side. i usually get the axle in the hub and the hold the hub like a steering wheel and ram that bitch in. you gotta get past the ring clip. try a rubber mallet. just keep the axle level when pushing on it.
Old Apr 3, 2005 | 11:05 AM
crxzcracer's Avatar
Default Re: 26 spline axle wont go into 26 spline tranny (mr. carpenter)
i have ramed the **** out of it and the mallet didnt do anything
what if i take that ring off would that help?
Old Apr 3, 2005 | 11:23 AM
no that's what holds it in once it's seated.
Old Apr 3, 2005 | 11:44 AM
crxzcracer's Avatar
but how would it fall out as i am driving
Old Apr 3, 2005 | 12:21 PM
it might not. go ahead and try it. someone can follow the trail of tranny fluid to come get you. if the axle does'nt seat you will lose fluid.
Old Apr 3, 2005 | 05:24 PM
Will_the_Thrill's Avatar
once again....shouldve bought mine....you know, i know where an 89 crx si just sits in a dudes front lawn....it'd be a shame if he lost them axles...lol j/k. You know, i could see if i can get the tranny off of him and we could try that. Hit me back to let me know
Old Apr 3, 2005 | 07:41 PM
travis's Avatar
Default Re: 26 spline axle wont go into 26 spline tranny (DSM2fastEG2clean)
I had this problem installing my axles into a new gearbox. If you bang the hell out of it with a rubber hammer (not a real hammer) it will go. The rubber hammer won't do much if any damage if the two parts aren't supposed to go together (like a BFH would). Mine took quite a bit of force since the two surfaces were new.
Old Apr 3, 2005 | 07:52 PM
Slow ass EF's Avatar
it will fall out trust me it has happened to me 3 times in 2 days before. i ended up buying an axle from honda and it hasnt given me any problems since
Old Apr 3, 2005 | 09:26 PM
crxzcracer's Avatar
Default Re: 26 spline axle wont go into 26 spline tranny (LSVTECJay)
well i had gone to auto zone last night to see if there was a difference in the axles and they were the same so today i was like **** it and went to advance and bought one compared and it te same damn thing but the **** just popped right it WTF i don't understated it but im driving my car now so i don't give a ****.
Old Apr 3, 2005 | 09:30 PM
the niz jiz's Avatar
Default Re: 26 spline axle wont go into 26 spline tranny (travis)
<TABLE WIDTH="90%" CELLSPACING=0 CELLPADDING=0 ALIGN=CENTER><TR><TD>Quote, originally posted by travis &raquo;</TD></TR><TR><TD CLASS="quote">I had this problem installing my axles into a new gearbox. If you bang the hell out of it with a rubber hammer (not a real hammer) it will go. The rubber hammer won't do much if any damage if the two parts aren't supposed to go together (like a BFH would). Mine took quite a bit of force since the two surfaces were new.</TD></TR></TABLE>
same thing here with my zc...wouldnt go in at first by hand....put some greese on both sides....put it on tha hub first,and kicked that **** in
Old Apr 3, 2005 | 09:38 PM
31flavorscivic's Avatar
Default Re: 26 spline axle wont go into 26 spline tranny (N.O.R.E)
<TABLE WIDTH="90%" CELLSPACING=0 CELLPADDING=0 ALIGN=CENTER><TR><TD>Quote, originally posted by mr. carpenter &raquo;</TD></TR><TR><TD CLASS="quote">spline count only matters on the outboard side. i usually get the axle in the hub and the hold the hub like a steering wheel and ram that bitch in. you gotta get past the ring clip. try a rubber mallet. just keep the axle level when pushing on it.</TD></TR></TABLE>
This is the redneck way to do it, just like mr. carpenter explained, just a little more detailed. I popped the CV one time so be careful. Prolly not the best way, but heres how I did it on my ZC.
I hooked it up on the hub side, and then pushed it in as far as it would go on the tranny side. Then I grabbed the hub and pulled it slowly toward me like a half inch, (not too far as you can pop the CV joints out) and then rammed it in. I did that three times and it seated.
A little grease helps too.
Modified by 31flavorscivic at 11:54 PM 4/4/2005
SIef9
Jan 15, 2012 05:13 PM
patwitahonda
Nov 9, 2009 05:27 PM
EJ8CIVIC
Jan 20, 2009 12:17 PM
crxzcracer
15
Sep 21, 2005 11:17 AM
ek_slut
May 12, 2005 08:11 PM
