M22/x/xx Cams in Stock SIR2?
Old Apr 3, 2005 | 10:49 AM
Fuzion's Avatar
Default M22/x/xx Cams in Stock SIR2?
My motor is completely stock. I have a 4-1 header vibrant/aebs itm/custom 2.5" exhaust/test pipe/ hondata s200. Will the cams ake good power or do i need more compression? my compression should be 10.4:1 or sumthing of that nature. Its a 95 jdm b16
Old Apr 3, 2005 | 12:50 PM
UncleD's Avatar
Default Re: M22/x/xx Cams in Stock SIR2? (Fuzion)
Rocket does not reccommend the M22's for a fairly stock b16. I would consider doing type r cams or maybe S2S1's
Old Apr 3, 2005 | 12:51 PM
GUILOTINE's Avatar
Kill Gil
Buddy club spec 3's where designed for stock compression
Old Apr 3, 2005 | 12:55 PM
1SlowB16EF's Avatar
Default Re: M22/x/xx Cams in Stock SIR2? (clean rice)
where can you buy? or research rocket cams?
johnzm's Avatar
Default Re: (GUILOTINE)
man put those cams in u will gain alot of daily power and some good top end, and then make plans in the future to increase compression to 11-11.5 and u will be set!
Old Apr 3, 2005 | 01:14 PM
5STAR3's Avatar
Default Re: M22/x/xx Cams in Stock SIR2? (1SlowB16EF)
<TABLE WIDTH="90%" CELLSPACING=0 CELLPADDING=0 ALIGN=CENTER><TR><TD>Quote, originally posted by 1SlowB16EF &raquo;</TD></TR><TR><TD CLASS="quote">where can you buy? or research rocket cams? </TD></TR></TABLE>
http://www.m24x.com/
<TABLE WIDTH="90%" CELLSPACING=0 CELLPADDING=0 ALIGN=CENTER><TR><TD>Quote, originally posted by johnzm &raquo;</TD></TR><TR><TD CLASS="quote">man put those cams in u will gain alot of daily power and some good top end, and then make plans in the future to increase compression to 11-11.5 and u will be set!</TD></TR></TABLE>
and with out upgrading valvetrain
g23cg5
Nov 15, 2013 04:58 AM
typeoneeg6
Sep 22, 2007 03:20 PM
The Destroyer
12
May 30, 2006 02:57 PM
tomlinson619
May 22, 2006 07:59 PM
bxsi
Apr 1, 2004 09:20 PM
