What rims/tires should I use for best times?
Old Apr 3, 2005 | 10:30 AM
one slow coupe's Avatar
Default What rims/tires should I use for best times?
Well here are my options.
I can run my stock si wheels with my stock tires( not sure what brand) lowered to about 20-22 psi
Or I could use my rays gram light 57cs (17 inch), with yokohama parada spec 2 tires with normal tire pressure.
Which tires set of wheels should I use to run the best times, I could lower the psi on the spec 2s but I dont think you can lower the pressure much on low profile tires?
Plus the gram lights are pretty heavy compared to the stock wheels, but they are almost brand new tires on them.
Old Apr 3, 2005 | 11:09 PM
T4eg's Avatar
Default Re: What rims/tires should I use for best times? (Honda_b16a2)
i would say get a good DR for your Si's .205-50-15 or 225-50-15 depending on setup.
vtek9
Aug 12, 2010 01:08 PM
talontsiawd
Mar 7, 2008 12:40 PM
Heinekim
Feb 3, 2007 06:46 AM
Shake and Bake
Feb 6, 2006 10:56 AM
94B18B1Teg
Dec 11, 2003 07:08 AM
