Maintenance Required Light.
Old Apr 3, 2005 | 10:01 AM
Default Maintenance Required Light.
What's up with this maintenance required light? It just came on after I started my car after the first time I parked it when it hit 142k miles. Can it be cleared just like check engine codes? I got a scanner that can clear codes here at my house. Please don't tell me that I have to get screwed over by the dealer to get the light to go away.
Old Apr 3, 2005 | 10:24 AM
accordselux's Avatar
Me Gusta History
Default Re: Maintenance Required Light. ("Hites")
All it does is tell you that youre at a certain mileage point for recommended maintenance, in your manual I think it tells you how to turn it off. You hold down the odo button or something, just look it up
Old Apr 3, 2005 | 11:38 AM
Default Re: Maintenance Required Light. (accordselux)
<TABLE WIDTH="90%" CELLSPACING=0 CELLPADDING=0 ALIGN=CENTER><TR><TD>Quote, originally posted by accordselux &raquo;</TD></TR><TR><TD CLASS="quote">All it does is tell you that youre at a certain mileage point for recommended maintenance, in your manual I think it tells you how to turn it off. You hold down the odo button or something, just look it up </TD></TR></TABLE>
only thing i looked at in the manual was the recommended scheduled maintainance mileages.
Old Apr 3, 2005 | 11:42 AM
Me Gusta History
I'm friends with a tech at a Honda dealership, and I have the same damned light. He said all I had to do was call and ask how to turn it off myself and he'd tell me. Just give the dealership a call and ask nicely how to turn the light off
Old Apr 3, 2005 | 11:58 AM
as_fast_as_u's Avatar
do this... 1. insert key in the ignition
2. push and hold the odometer reset button
3. while holding the odometer reset button turn the ignition key to "on" but dont start the car... hold in that position for 15 sec.
the maintance required light will flash a few times and then dissapear for good...good luck
Old Apr 3, 2005 | 12:35 PM
philadd's Avatar
Default Re: (gude_f23a1)
It comes on every 7500 miles....
Dilly
Mar 19, 2008 06:33 AM
silver_gun
Honda Civic (2001 - 2005)
Jul 22, 2007 02:52 PM
hondalove456
62
Apr 20, 2007 10:09 PM
ROB8387
Dec 16, 2006 02:00 PM
B33R
Mar 26, 2006 10:16 AM
