moroso oil pan. Added 5 qrts and STILL no reading on the dipstick
Old Apr 3, 2005 | 08:40 AM
Ls1 FD3s's Avatar
Default moroso oil pan. Added 5 qrts and STILL no reading on the dipstick
Like the topic says. 5 qrts without changing the oil filter and it didnt even register on the dipstick. What gives? I mean **** as if 5 qrts wasnt enough, now i need 1/2 quart or more? lol Different dipdtick maybe? I dunno. thanks to all that help me out provide info.
Old Apr 3, 2005 | 09:42 AM
non-VTEC's Avatar
Default Re: moroso oil pan. Added 5 qrts and STILL no reading on the dipstick (Ls1 FD3s)
its probaby a combination of the size of the pan and maybe you need a longer dip stick for that pan........but 5 quarts should be enough.........
Old Apr 3, 2005 | 10:09 AM
Phase Change Racing's Avatar
Put the drain plug back in. ;-) What is the capacity of that pan supposed to be?
Old Apr 3, 2005 | 12:03 PM
Combustion Contraption's Avatar
You probably just need a longer stick (heh) to read the actualy capacity of that of that pan.
Old Apr 3, 2005 | 01:24 PM
It is the height of the oil in the pan relative to the oil pump pickup that is important, the depth of the pan should not change that and thus, you should not need a different dipstick.
Old Apr 3, 2005 | 03:19 PM
Ls1 FD3s's Avatar
Default Re: (Phase Change Racing)
Moroso 5 quart oil pan. So 5 quarts.
Its at least 3inches deep. Before i installed my oil return line, the oil was overflowing through the fitting right after i dumped in the last quart. the oil pickup is more than deep in oil for sure.
The dipstick issue had me wondering...
latinman07
Jan 2, 2013 10:01 PM
