4th and 5th gear to fit in s1 Trans
Old Apr 3, 2005 | 08:38 AM
89'dualpoint's Avatar
Default 4th and 5th gear to fit in s1 Trans
Hi,
I just put an s1 trans in my 93 ls and im real happy with it except for the fact that i can barely drive it down the highway. I want to put a longer 4th and 5th in the car. If not that atleast a better 5th. At 80 mph im at about 4800 rpm's. I have been told that i can use the 1990-1991 ls 4th and 5th but im not sure. I tried using the ls gears from my car but they had a much larger inside diameter. If anyone knows what gears will fit on the shafts of this s1 trans that would be a big help.
THanks in advance,
Steve
Old Apr 3, 2005 | 07:41 PM
jasyatz's Avatar
Default Re: 4th and 5th gear to fit in s1 Trans (89'dualpoint)
Hey..
You've really only got 3 choices:
1) Find a 90-91 LS gearbox and build a custom gearset out of that and your S1..
2) Give that S1 back to the guy who sold it tou you and find a GSR gear set and an ITR diff and build a decent trans out of the 2 of them..
3) Get your LS trans back and buy an aftermarket final drive set with another type of LSD unit(Quaife or Something like that)
Keep you eyes out for a blown up or apart GSR trans any year or a 90-91 LS trans..
Jeff
Also..Keep your eyes out for a t25/T28 turbo kit/or pieces...I have a project for you and the welder..
Old Apr 3, 2005 | 07:44 PM
efcivic757's Avatar
4800 at 80. Thats not bad. Try a b16 j1 tranny. I was at 5k at just above 70mph.
civiceagle2
Jul 10, 2016 09:20 PM
alwaystootall
Aug 23, 2009 08:53 AM
killerpenguin21
Aug 29, 2007 06:23 PM
