Decision/Question on swap
Old Apr 3, 2005 | 06:40 AM
SexyAzNMami's Avatar
Default Decision/Question on swap
I made up my mine and decided my crx needs a engine swap. I see boosting it down the line but not quiet too sure about it. Here's the 3 type of motors that I was thinking about for the engine swap. I need your opinions on them. Bad/Good, what not? Flaming is welcome too. Just cause i'm a lady doesn't mean I can't do it. So if you're going to flame, don't flame me on the female issue. Thanks.
96 B18C (GSR)
97 B18C (Type R)
95 H22a
http://www.fem-tech.com/
Old Apr 3, 2005 | 06:49 AM
Fred n J_v2.0's Avatar
Default Re: Decision/Question on swap (SexyAzNMami)
Well, if your plans are for boost down the line, out of the three engines you selected I would go with the GSR... the h22 does not have mounts available to fit in your crx, so it would be a custom mount up. (although, hasport is supposedly workin on a set of mounts for the h22-ef swaps)
the typeR motor would not be worth the extra money if you plan on boosting later, since everything that makes the ITR motor different than the gsr, you would be replacing anyways.
try searching thru the archives here as there is plenty of information to be found. also try the all-motor and forced induction forums for more info.
good luck
Old Apr 3, 2005 | 07:02 AM
Thanks Fred!
fuzzysig
K Series
Dec 8, 2017 08:26 PM
TNight
18
Jun 22, 2014 09:09 AM
trojan
Sep 6, 2011 10:10 AM
low430
Sep 11, 2005 06:37 PM
Addijhaq
Apr 24, 2005 07:27 PM
