hi flow oil and hi flow water pumps?
Bump for info, I don't think that anyone makes em, or that they would be even necessary for any application on our cars, but someone prove me wrong.
<TABLE WIDTH="90%" CELLSPACING=0 CELLPADDING=0 ALIGN=CENTER><TR><TD>Quote, originally posted by 93formula »</TD></TR><TR><TD CLASS="quote">do they make em for the d16s? where would i find em? and are they worth it on a boosted motor?</TD></TR></TABLE>
Don't worry about it. You can just replace both with stock ones if you're worried about failure. You shouldn't have any problems. How much are you planning on boosting?
high volume oil pump for most honda applications can be found on http://www.importperformanceparts.net
<TABLE WIDTH="90%" CELLSPACING=0 CELLPADDING=0 ALIGN=CENTER><TR><TD>Quote, originally posted by Mr. S »</TD></TR><TR><TD CLASS="quote">
Don't worry about it. You can just replace both with stock ones if you're worried about failure. You shouldn't have any problems. How much are you planning on boosting?</TD></TR></TABLE>
enough boost to hit 300 hp, thats the goal. as im rebuilding the motor thought id put in hiflow units if available.
thanks for the link hatchblack
