projected DYNO numbers 1.8 B18C
Old Apr 2, 2005 | 09:58 PM
DC2_TypeR's Avatar
Default projected DYNO numbers 1.8 B18C
hey guys , im curious to know what my WHP "should" be at , im aware that no two motors are similar and with that said here's a breakdown of the current mods
Motor : 2000 JDM ITR
Head : NO PORT AND POLISH
AEM short ram
Ericks racing 70mm TB
AEBS Intake Manifold /with Hondata cooling gasket
Buddy Club SpecIII+'s cams
Skunk2 cam gears
Omni Valve Springs /Retainers
JG 4-2-1 Polished headers
Fuel : Stock Fuel pump
Lucas 370 cc injectors
AEM fuel rail
Ericks Racing FPR
Block: STOCK JDM ITR 11.1 compression
ECU : P28 w/ a Hondata S200
Exhaust: 2 1/2 Straight pipe w/ RSR EX MAG muffler
and POWERSTEERING
if anyone can shed some light on "what" it should look like on the dyno , would be greatly appreciated!
Modified by DC2_TypeR at 10:38 AM 4/3/2005
Old Apr 2, 2005 | 10:29 PM
itralex's Avatar
Default Re: projected DYNO numbers 1.8 B18C (DC2_TypeR)
probable around low 190 or high 180
Old Apr 2, 2005 | 10:34 PM
jthm's Avatar
Default Re: projected DYNO numbers 1.8 B18C (itralex)
That intake manifold might rob you of some hp, and definetly some low end if the itr's use butterfly vavles, unless you are going to be using NOS.
Old Apr 2, 2005 | 11:29 PM
GOLDBERG's Avatar
Default Re: projected DYNO numbers 1.8 B18C (squee)
<TABLE WIDTH="90%" CELLSPACING=0 CELLPADDING=0 ALIGN=CENTER><TR><TD>Quote, originally posted by squee &raquo;</TD></TR><TR><TD CLASS="quote">That intake manifold might rob you of some hp, and definetly some low end if the itr's use butterfly vavles, unless you are going to be using NOS.</TD></TR></TABLE>
what the HELL are you talking about??since when did a itr have butterflies in there intake manifolds..... dont post **** like that if you dont know what your talking about..also the aebs has been dyno proven too make more power than the itr manifold..........
Old Apr 3, 2005 | 03:04 AM
jthm's Avatar
Default Re: projected DYNO numbers 1.8 B18C (GOLDBERG)
<TABLE WIDTH="90%" CELLSPACING=0 CELLPADDING=0 ALIGN=CENTER><TR><TD>Quote, originally posted by GOLDBERG &raquo;</TD></TR><TR><TD CLASS="quote">what the HELL are you talking about??since when did a itr have butterflies in there intake manifolds..... dont post **** like that if you dont know what your talking about..also the aebs has been dyno proven too make more power than the itr manifold..........</TD></TR></TABLE>
Yea, I wasnt sure, that is why I used the words "might" and "if" The aebs manifold has been proven to make more power I'm sure, but with what mods? Just because an intake is larger does not mean necessarily that it will make more hp. You have to have the need for a larger intake. A lot of the time an extrude honed stock manifold will make more power over an aftermarket. I do not know that much about aeb in particular which is why I chose my words carefully, and because I was trying to avoid being bashed by you. Quickly bashing my response, and not taking the time to thoroughly read through or understand it makes you not only look like a dick, but also someone who doesnt understand the definition of simple elementary words. CHILL PLEASE!
Old Apr 3, 2005 | 04:38 AM
GOLDBERG's Avatar
yeah well..when has a itr manifold ever had dual runners and butterflies??your thinking of a gsr manifold.......
Old Apr 3, 2005 | 05:36 AM
jthm's Avatar
<TABLE WIDTH="90%" CELLSPACING=0 CELLPADDING=0 ALIGN=CENTER><TR><TD>Quote, originally posted by GOLDBERG &raquo;</TD></TR><TR><TD CLASS="quote">yeah well..when has a itr manifold ever had dual runners and butterflies??your thinking of a gsr manifold.......</TD></TR></TABLE>
Read my post again, it says "if".
Modified by squee at 9:48 AM 4/3/2005
Old Apr 3, 2005 | 07:18 AM
moto1320's Avatar
I think you should do better then high 180's to low 190's with that set up. Last week we made 184 or 5 (can't remember) without half of that stuff on a JDM Type-R. Stock injectors, cams, AEM CAI, CR, crappy old temporary DC 4-2-1 header, with Hondata s100. Tuning will wring a pretty good powerband out of that setup that should hit 200 easy. If we don't cross 200 WHP on the motor I mentioned once we hang a good header and get some cams in there I'll freak.
Old Apr 3, 2005 | 09:17 AM
DC2_TypeR's Avatar
just for final clarifacation , the ITR motor doesn't have the dual butterflies
<TABLE WIDTH="90%" CELLSPACING=0 CELLPADDING=0 ALIGN=CENTER><TR><TD>Quote, originally posted by moto1320 &raquo;</TD></TR><TR><TD CLASS="quote">I think you should do better then high 180's to low 190's with that set up. Last week we made 184 or 5 (can't remember) without half of that stuff on a JDM Type-R. Stock injectors, cams, AEM CAI, CR, crappy old temporary DC 4-2-1 header, with Hondata s100. Tuning will wring a pretty good powerband out of that setup that should hit 200 easy. If we don't cross 200 WHP on the motor I mentioned once we hang a good header and get some cams in there I'll freak.</TD></TR></TABLE>
what kinda dyno was this on?
i've herd different dyno's produce diferent numbers, meaning you can have 2 identical dyno's and run the same car , same mods and you will end up with 2 different dyno sheets. Is this true?
Old Apr 3, 2005 | 09:24 AM
DC2_TypeR's Avatar
after final tuning before some items were purchased
the car put down 175whp/126tqe on 12/7/2004 @ <U>RAGE </U>
the mods were
J's racing CF intake
Ericks racing 70mm
AEBS I.M.
STOCK TYPE R CAMS
Skunk2 cam gears adjusted (advanced/retarded)
B&M FPR
JG 4-2-1 headers
2 1/2 exhaust with an RSR EX MAG muffler
and a fields Vtec controller
ohhh , and all this is still being done w/ power steering
Modified by DC2_TypeR at 10:36 AM 4/3/2005
Old Apr 3, 2005 | 09:39 AM
PyroProblem's Avatar
Id say 190-200 whp(depending on the dyno used) and about 135tq...
Old Apr 5, 2005 | 03:41 AM
moto1320's Avatar
Dyno Jet
eg6 type-R
38
Jan 5, 2012 11:10 PM
cjb92
32
Nov 17, 2007 02:44 PM
yoorang
Sep 17, 2006 09:44 PM
Captain Save-a-Hoe
Apr 4, 2003 04:45 PM
Captain Save-a-Hoe
Apr 4, 2003 01:17 PM
