How to replace speed sensor cable
Old Apr 2, 2005 | 09:33 PM
85mm LS VTEC's Avatar
Default How to replace speed sensor cable
I need to know how to replace the speed sensor cable in a 90 hatch and will a 90-93 Integra speed sensor cable work in its place?
Old Apr 2, 2005 | 09:47 PM
eda6's Avatar
Default Re: How to replace speed sensor cable (85mm LS VTEC)
To replace the speedo cable disconnect the cable from the back of the vss. Disconnect the other end from the vss. Remove cable. Install the new one and put everything back together. Not sure if the DA cable will work.
Old Apr 4, 2005 | 10:51 AM
strictlyimport's Avatar
just replaced mine this past week. make sure after you disconnect the 2 ends you tie a rope to the tranny end. it will make things much easier. then just pull it through and out the dash. when you re-route it, it gets a little tricky going through the firewall, goes just behind the lower half of your center console. be sure you don't loose the clip at the tranny end. when you get the cable routed, put the clip on the VSS housing first, then just slide the cable into the tranny until you here it click, then give it a little tug to make sure that it is in its place............any questions, just pm me.
Old Apr 4, 2005 | 10:52 AM
Default Re: How to replace speed sensor cable (eda6)
what black piece are you refering to.....the part that houses the radio and climate controls? let me know.....i have a extra one lying around at the house....
jadugartir
Feb 23, 2005 07:08 PM
jcrou
Dec 17, 2004 08:56 AM
ron b
Apr 29, 2004 10:49 AM
sleepin91teg
Apr 15, 2004 02:08 PM
Russ
Jan 26, 2004 09:41 AM
