will portflow inner valve springs be compatible with bc3+ cams?
Old Apr 2, 2005 | 08:40 PM
jeremy.'s Avatar
Default will portflow inner valve springs be compatible with bc3+ cams?
this is all going in a stock type r head...thinking about swapping out the inner valve springs only when putting in my buddy club spec 3 cams...are stock itr retainers enough also?
Old Apr 2, 2005 | 09:01 PM
sheepey's Avatar
yes
Old Apr 2, 2005 | 09:19 PM
jeremy.'s Avatar
Default Re: (sheepey)
no chance of binding?
Old Apr 2, 2005 | 09:20 PM
sheepey's Avatar
nope
Old Apr 3, 2005 | 01:19 PM
GUILOTINE's Avatar
Kill Gil
already told you that puto.... check this out
Buddy ClubIII+ 11.2mm, duration 296@1mm 11.5mm, duration- 290@1mm
Integra Type R 11.5 mm, duration - 240 @ 1mm 10.5 mm, duration - 235 @ 1mm
On the exhaust the max lift portflow/itr exhaust springs are designed to handle is 11.5 so you are ok They can Hadle 12.5 on the intake. These words came straight from Tom's mouth
Old Apr 3, 2005 | 01:22 PM
1SlowB16EF's Avatar
1mm lift should me no where near binding those bad boys
Old Apr 3, 2005 | 01:24 PM
GUILOTINE's Avatar
Kill Gil
Default Re: (1SlowB16EF)
<TABLE WIDTH="90%" CELLSPACING=0 CELLPADDING=0 ALIGN=CENTER><TR><TD>Quote, originally posted by 1SlowB16EF &raquo;</TD></TR><TR><TD CLASS="quote">1mm lift should me no where near binding those bad boys</TD></TR></TABLE>
HUH?
Old Apr 6, 2005 | 06:59 PM
DOMKID's Avatar
Default Re: (GUILOTINE)
what about BC4?
Old Apr 7, 2005 | 08:54 AM
GUILOTINE's Avatar
Kill Gil
Default Re: (Dominican_Kid)
<TABLE WIDTH="90%" CELLSPACING=0 CELLPADDING=0 ALIGN=CENTER><TR><TD>Quote, originally posted by Dominican_Kid &raquo;</TD></TR><TR><TD CLASS="quote">what about BC4?
if you have yellows on the outer exhaust side, they will be fine.
Old Apr 18, 2005 | 12:14 PM
jeremy.'s Avatar
someone help me find a place to purchase portflow inners
Old Apr 18, 2005 | 02:58 PM
PURPLETERROR aka BIGMATT's Avatar
Default Re: (ekay_jeremy)
Try portflow
Old Apr 18, 2005 | 03:03 PM
jeremy.'s Avatar
Default Re: (PURPLETERROR)
already did with no joy
Old Apr 18, 2005 | 03:14 PM
GUILOTINE's Avatar
Kill Gil
you called and talked to Tom?
Old Apr 18, 2005 | 03:49 PM
DC2_TypeR's Avatar
http://www.camp1320motorsports.com
talk to TOM like Guilotine said manye!!!!!!
Old Apr 19, 2005 | 02:31 AM
oldskool teggy's Avatar
you mean portflow inners and ITR outter combo? <TABLE WIDTH="90%" CELLSPACING=0 CELLPADDING=0 ALIGN=CENTER><TR><TD>Quote, originally posted by GUILOTINE &raquo;</TD></TR><TR><TD CLASS="quote">already told you that puto.... check this out
On the exhaust the max lift portflow/itr exhaust springs are designed to handle is 11.5 so you are ok They can Hadle 12.5 on the intake. These words came straight from Tom's mouth </TD></TR></TABLE>
Old Apr 19, 2005 | 03:21 AM
137's Avatar
137
Default Re: (Oldskool teggy)
http://www.alaniztechnologies.com
Joe might have what you need.
CaseBone
May 22, 2006 01:26 AM
asocallocal
16
Sep 11, 2005 11:40 AM
oMek
Jan 17, 2004 08:19 PM
EF'n
Apr 9, 2002 06:59 PM
StinkyTofu
Feb 8, 2002 10:17 AM
