Changing oil on my new gsr...searched but imm too lazy to go through them
Old Apr 2, 2005 | 08:11 PM
kidGSR's Avatar
Default Changing oil on my new gsr...searched but imm too lazy to go through them
I just bought a 95 gsr and i wanted to know what the best oil i can use. If it helps the car has 131xxx miles on it. I wanna keep it Mobil 1 but i dont know if full synthetic, synthetic, or 10w or 5w.???
Lemme know thanks
Old Apr 2, 2005 | 09:02 PM
SYTFU Tommy.'s Avatar
Default Re: Changing oil on my new gsr...searched but imm too lazy to go through them (kidGSR)
normally on any honda, i just use castrol 10w-30. it all depends on the weather is in your weather. to me personally, i dont think there is much differnce with the synthetic and normal oil. oil is oil IMO
Old Apr 2, 2005 | 09:37 PM
mickey513's Avatar
<TABLE WIDTH="90%" CELLSPACING=0 CELLPADDING=0 ALIGN=CENTER><TR><TD>Quote, originally posted by kidGSR &raquo;</TD></TR><TR><TD CLASS="quote">I just bought a 95 gsr and i wanted to know what the best oil i can use. If it helps the car has 131xxx miles on it. I wanna keep it Mobil 1 but i dont know if full synthetic, synthetic, or 10w or 5w.???
Lemme know thanks</TD></TR></TABLE>
On a car like this, you are better off running the high mileage motor oil from companies like Vavoline, Castrol, Pennzoil etc.,
Old Apr 2, 2005 | 10:21 PM
phateless's Avatar
here goes the story. as far as wive's tale vs reality, i have no clue. sometimes in older engines the only thing blocking potential leaks is built up crud. you run synthetic oil, it can clean out the crud, and all of a sudden you have a leak. that being said, i switched to motul full synthetic 5w30 in my car at 140k with no problems. i just turned over 150k and it doesn't lose or burn a damn drop of oil. if you run it hard, run full synthetic. i can tell the difference. and if your car is well kept, don't deviate from the specified oil weight. it usually says on the oil filler cap. honda engines are very precise, they specify 5/30 for a reason.
Old Apr 3, 2005 | 07:43 AM
Rpizzle's Avatar
Castrol high mileage 10w30, and I add a can of RESTORE with every change, and you get more power, you can fell the power come back. also I use FRAM Double gaurd for that dirt
Old Apr 3, 2005 | 10:14 AM
kidGSR's Avatar
Default Re: Changing oil on my new gsr...searched but imm too lazy to go through them (Rpizzle)
thanks for the replies ok now is it 5w10 or 10w30. THe past owner put in 10w30 synthetic but since im a car enthusiast i dunno wut to put. ANd the condition on the car is very clean In and Out paint and all for 5'gs i think i found the perfect first car. AND i wanna keep it running strong too.
Old Apr 3, 2005 | 10:25 AM
Finger Lickin' good's Avatar
10w30 to be safer. 5w30 works too. Higher mileage oils are thicker however.
Old Apr 3, 2005 | 12:47 PM
kidGSR's Avatar
Default Re: Changing oil on my new gsr...searched but imm too lazy to go through them (D-CeReaL#4)
K thanks alot guys, i appreciated.
Old Apr 3, 2005 | 02:00 PM
phateless's Avatar
5/30 unless you're worried about burning or leaking. use what honda reccomends.
SiReflex
Jul 4, 2007 08:50 PM
SpoonFedHatch
Jul 10, 2004 08:51 PM
HUBB
12
Apr 24, 2004 01:53 PM
acuraholic
Mar 27, 2003 10:17 AM
whtrice01gsr
Jul 13, 2002 02:13 PM
