Question on how to plug up the water log nipple
Old Apr 2, 2005 | 08:00 PM
tunedek's Avatar
Default Question on how to plug up the water log nipple
Hey thowing together an LS VTEC motor. The water log I am using comes from a VTEC block. I do not have the oil cooler that went with this VTEC water log setup. I need to close off this nipple any suggestions? A few pics of the buildup too for your entertainment. Thanks.
Old Apr 2, 2005 | 08:41 PM
tunedek's Avatar
Default Re: Question on how to plug up the water log nipple (tunedek)
TTT
Old Apr 2, 2005 | 09:11 PM
Lord Helmet's Avatar
fastest route I can't think of is to cut off the nipple and weld a small plate over the hole. Be careful with welding it into the pipe because it is not that thick. Or just use a LS water log and be done with it.
Old Apr 2, 2005 | 09:39 PM
tunedek's Avatar
Default Re: Question on how to plug up the water log nipple (sleeperciv)
Good idead (LS log). If I use the LS water log though do I have to use the LS thermostat housing?
Old Apr 2, 2005 | 09:47 PM
<TABLE WIDTH="90%" CELLSPACING=0 CELLPADDING=0 ALIGN=CENTER><TR><TD>Quote, originally posted by tunedek &raquo;</TD></TR><TR><TD CLASS="quote">Good idead (LS log). If I use the LS water log though do I have to use the LS thermostat housing? </TD></TR></TABLE>
no the ls and gsr have the same thermostat housing.
Old Apr 3, 2005 | 12:54 AM
tunedek's Avatar
I am using a JDM ITR housing. Now does this make a difference? Just need to know what to pull when I go to the junk yard on Monday.
Old Apr 3, 2005 | 01:04 PM
<TABLE WIDTH="90%" CELLSPACING=0 CELLPADDING=0 ALIGN=CENTER><TR><TD>Quote, originally posted by tunedek &raquo;</TD></TR><TR><TD CLASS="quote">I am using a JDM ITR housing. Now does this make a difference? Just need to know what to pull when I go to the junk yard on Monday.</TD></TR></TABLE>
I highly doubt there would be any difference compare to the USDM ITR. For the junkyard get the LS water pipe and the hoses connecting to the thermostat housing since the LS differs from the B18C5/C1 engine because of the oil cooler coolant hoses they have.
Old Apr 3, 2005 | 03:05 PM
tunedek's Avatar
thanks boss
Old Apr 4, 2005 | 04:41 AM
drumking15's Avatar
dammit...i just had to make custom hose to put in my oil cooler...i would have sent you a ls water pipe in trade.....grrrr
Old Apr 4, 2005 | 06:04 AM
tgreaves's Avatar
Default Re: (drumking15)
If you want to plug it, I would say to take a hose and put a bolt into it and jb weld it into the hose, also put a hose clamp around the bolt/hose and then put it back on..
Old Apr 4, 2005 | 10:47 AM
tunedek's Avatar
Default Re: (tgreaves)
<TABLE WIDTH="90%" CELLSPACING=0 CELLPADDING=0 ALIGN=CENTER><TR><TD>Quote, originally posted by tgreaves &raquo;</TD></TR><TR><TD CLASS="quote">If you want to plug it, I would say to take a hose and put a bolt into it and jb weld it into the hose, also put a hose clamp around the bolt/hose and then put it back on..</TD></TR></TABLE>
I have thought about that. But then I am concerned about the longevity of that plug in a hose. It is a consideration though.
I have also thought about just putting a cap on the and clamp that would go over the clamp. I am going to go and visit the "Hoseman" today (acutually shop here that is badass! for any hose/fitting you need) and see what they have to say there.
andyman97
Honda Civic (2001 - 2005)
27
May 5, 2011 08:10 PM
DDTECH
Sep 17, 2009 07:53 PM
00EKLSVtec
Dec 22, 2008 07:47 PM
918eg
Feb 24, 2008 08:14 AM
Timmay
12
May 17, 2007 05:14 PM
