Quick Downpipe Question, 2.5 or 3 on SOHC t3 turbo?
Old Apr 2, 2005 | 07:32 PM
BigMoneyP's Avatar
Default Quick Downpipe Question, 2.5 or 3 on SOHC t3 turbo?
should I go with a 2.5 downpipe or 3inch on a stock d16y7 with a t3 garret/airesearch 42/48 60 trim? I don't have A/C so space wouldn't be a problem. I did read about some lag spikes.. I'm looking to boost 9/10 lbs on a stock motor with hopefully around 200whp. Real close to buying the bmc LOG mani/3inch downpipe... Pls give me some feedback.
Old Apr 2, 2005 | 10:34 PM
moomakudafi's Avatar
Default Re: Quick Downpipe Question, 2.5 or 3 on SOHC t3 turbo? (BigMoneyP)
do the 3", it will let the turbo breathe better so spool up is a little quicker. also, what size exhaust are you runin? some people like to run same size all the way through. up to you but im runnin a 3" and love it. open downpipe growl *such a sexy sound*
Old Apr 3, 2005 | 12:03 PM
BigMoneyP's Avatar
Default Re: Quick Downpipe Question, 2.5 or 3 on SOHC t3 turbo? (moomakudafi)
<TABLE WIDTH="90%" CELLSPACING=0 CELLPADDING=0 ALIGN=CENTER><TR><TD>Quote, originally posted by moomakudafi &raquo;</TD></TR><TR><TD CLASS="quote">do the 3", it will let the turbo breathe better so spool up is a little quicker. also, what size exhaust are you runin? some people like to run same size all the way through. up to you but im runnin a 3" and love it. open downpipe growl *such a sexy sound*</TD></TR></TABLE>
great.. so it's not an overkill on a stock d16y7 with a t3 60 trim turbo right? I just don't want to go over board with it and have problems (spike or lose power).. I will be running a 3 inch exhaust as well so 3 inch piping all the way.
Modified by BigMoneyP at 8:13 PM 4/3/2005
Old Apr 3, 2005 | 02:07 PM
92civicb18b1's Avatar
i dont think that little d is going to sppol up that t4.
I would get the 3" DP though.
Old Apr 3, 2005 | 02:14 PM
igo4bmx's Avatar
my car just was finished today
first state was awesome enough to fabricate a 3 inch downpipe and KEEP a/c in there!!!
its on my d16y8
Old Apr 3, 2005 | 02:46 PM
Evanmb44's Avatar
Default Re: (igo4bmx)
definately go with the 3" all the way
Old Apr 3, 2005 | 03:01 PM
oxSLEEPERxo's Avatar
Default Re: (Turboaddict)
if you can fit 3", then go with 3"
Old Apr 3, 2005 | 04:19 PM
BigMoneyP's Avatar
Default Re: (oxSLEEPERxo)
the 3 inch should clear Power steering on my hatch right? I don't have A/c.. it's for a 99 dx hatch non a/c.. how much more power would it make over a 2.5 DP?
Old Apr 3, 2005 | 05:45 PM
Default Re: (BigMoneyP)
power is not what you will gain but it will let the turbo breathe better. the faster you can get the air in and out of the motor, the better. the 3" will be your best bet
Old Apr 3, 2005 | 07:00 PM
T4eg's Avatar
<TABLE WIDTH="90%" CELLSPACING=0 CELLPADDING=0 ALIGN=CENTER><TR><TD>Quote, originally posted by Turboaddict &raquo;</TD></TR><TR><TD CLASS="quote">definately go with the 3" all the way</TD></TR></TABLE>
Old Apr 3, 2005 | 07:13 PM
BigMoneyP's Avatar
Default Re: Quick Downpipe Question, 2.5 or 3 on SOHC t3 turbo? (92civicb18b1)
<TABLE WIDTH="90%" CELLSPACING=0 CELLPADDING=0 ALIGN=CENTER><TR><TD>Quote, originally posted by 92civicb18b1 &raquo;</TD></TR><TR><TD CLASS="quote">i dont think that little d is going to sppol up that t4.
I would get the 3" DP though.</TD></TR></TABLE>
sorry I meant t3.. looks like ill be purchasing the bmc log mani/ 3 inch downpipe combo!
Old Apr 3, 2005 | 07:22 PM
Bailhatch's Avatar
Port out the internal WG hole a few mm too. It will help you control boost better and doesnt really cost anything to do if you have the tools.
Old Apr 3, 2005 | 07:49 PM
BigMoneyP's Avatar
Default Re: Quick Downpipe Question, 2.5 or 3 on SOHC t3 turbo? (Bailhatch)
<TABLE WIDTH="90%" CELLSPACING=0 CELLPADDING=0 ALIGN=CENTER><TR><TD>Quote, originally posted by Bailhatch &raquo;</TD></TR><TR><TD CLASS="quote">Port out the internal WG hole a few mm too. It will help you control boost better and doesnt really cost anything to do if you have the tools.</TD></TR></TABLE>
not quite sure what you mean by this. i'm planning on getting a tial wastegate.. perhaps a 38mm one. where would this internal WG hole be located?
Old Apr 3, 2005 | 07:51 PM
Bailhatch's Avatar
nevermind then, you will be blocking off the internal WG hole with your DP flange. The 38mm Tial will flow just fine
Old Apr 3, 2005 | 07:55 PM
BigMoneyP's Avatar
i do think 38 would be good enough, what size would you guys recommend on this 3 inch DP
Old Apr 15, 2005 | 02:03 AM
96-EJ6 B18C's Avatar
<TABLE WIDTH="90%" CELLSPACING=0 CELLPADDING=0 ALIGN=CENTER><TR><TD>Quote, originally posted by BigMoneyP &raquo;</TD></TR><TR><TD CLASS="quote">i do think 38 would be good enough, what size would you guys recommend on this 3 inch DP</TD></TR></TABLE>
Your 38mm should be fine...I'm controling boost perfectly (no spikes and no creep) on my 60 trim T3 using a TiAl 35mm, using a custom made tubular manifold, similar to this...
http://www.alienauto.com Thanks again Justin!!!
Manifold design plays a big part in how well the WG is able to control boost though, my SSAC pos with the same WG spiked like a bitch (like 4 psi) and crept about 2 psi.
Old May 4, 2005 | 04:17 PM
BigMoneyP's Avatar
Default Re: Quick Downpipe Question, 2.5 or 3 on SOHC t3 turbo? (96-EJ6 B18C)
what a great looking manifold.
Old May 4, 2005 | 04:21 PM
ajusaf's Avatar
does the HF manifold allow you to keep your A/C with a 2.5 downpipe?
Old May 4, 2005 | 05:00 PM
huntarrr's Avatar
Default Re: Quick Downpipe Question, 2.5 or 3 on SOHC t3 turbo? (ajusaf)
HF mani's are not a/c friendly.
Old May 4, 2005 | 05:03 PM
ajusaf's Avatar
Default Re: Quick Downpipe Question, 2.5 or 3 on SOHC t3 turbo? (vsm98civic)
your kidding me dang it i want my a/c
Old May 4, 2005 | 06:22 PM
TurboTagTeam's Avatar
You think wrong. My y7 w/ a t4 hits full boost(8psi)at 4500 and pulls all the way to red. There is a little lag but that just gives you time to tighten you'r seatbelt.
Old May 4, 2005 | 06:27 PM
Slammd Sol's Avatar
Comon man, this is honda tech. 3" is way to small. You're gonna need at least a 4-5" 'er.
/sarcasm
Old May 5, 2005 | 08:00 AM
doubleA's Avatar
Default Re: (Slammd Sol)
I plan on running 2.5inch turbo back with no cat and one magnaflow bullet straight through muffler. Personally I think 3" is a little overbored for a sohc but are we bolting turbo's to our honda's to not go overbored? I don't think so. If you can afford 3" go for it man!
Old May 5, 2005 | 09:30 AM
mattssi's Avatar
Default Re: (doubleA)
<TABLE WIDTH="90%" CELLSPACING=0 CELLPADDING=0 ALIGN=CENTER><TR><TD>Quote, originally posted by doubleA &raquo;</TD></TR><TR><TD CLASS="quote">I plan on running 2.5inch turbo back with no cat and one magnaflow bullet straight through muffler. Personally I think 3" is a little overbored for a sohc but are we bolting turbo's to our honda's to not go overbored? I don't think so. If you can afford 3" go for it man!</TD></TR></TABLE>
I've heard this setup before. Be prepard to get earplugs. It is really raspy loud.
Old May 5, 2005 | 09:34 AM
yellowturbo's Avatar
3 inch DP on my SOHC.... if you can fit it go with the 3 inch.
