TypeR ECU
Old Jan 27, 2002 | 05:09 PM
mugenracer's Avatar
Default TypeR ECU
I jave a jdm Integrs Si, does anyone know if a typeR ECu will work in the Si/GSR, i know the inlet manifolds are different, will this make a difference in that the Si manifold wont open its secondary runners at 6000rpm as the type R ECU wont recognise the sensor from it????
Old Jan 27, 2002 | 05:14 PM
Reid's Avatar
Global Moderator
Default Re: TypeR ECU (mugenracer)
A GSR motor with a stock intake manifold should not be run with an ITR ECU, as the secondary butterflies are no longer controlled.
Old Jan 27, 2002 | 05:20 PM
mugenracer's Avatar
Default Re: TypeR ECU (Reid)
thanks..thats what i thought...just one more question, is the header on the ITR the same as the Si, (i know where theres a crashed ITR and was thinking of changing headers, or would i be better to go for a DC or comptech header?
Old Jan 27, 2002 | 05:58 PM
nwarp's Avatar
I dont think you want a USDM ITR header, more like the JDM 4-1's
turkdog
Nov 30, 2003 06:15 AM
gsrinstyle
Oct 15, 2003 05:50 PM
smkngsr
Sep 23, 2003 01:16 AM
d0nkeyxPunch
Dec 10, 2001 08:25 AM
