crx obd0 to obd1 conversion ?????
Old Apr 2, 2005 | 01:54 PM
da2slow's Avatar
New User
Default crx obd0 to obd1 conversion ?????
i bought the conversion harness to change the obd0 ecu to an obd1 ecu(p28), and i also swapped a 95 civic si hatch engine in too. has anywone had any problems with the conversion or if its a waste on time, b/c i 've got everything wired up and the fuel pump wont turn on and the ignition wont fire and the engine has a good distributor, somebody please help, anyhelp would greatly be appreciated.
thnx,
KC
Old Apr 2, 2005 | 04:37 PM
NikoZai's Avatar
Default Re: crx obd0 to obd1 conversion ????? (da2slow)
So you've changed all the wiring in the engine bay for OBD1.. OBD1 distributor, 4-wire O2 sensor etc..
Check your battery and grounds. Which conversion harness did you get?
bmcp.
Northwest (Sales)
Nov 13, 2010 02:02 PM
Swipe'd
May 27, 2008 08:46 AM
Swipe'd
Feb 14, 2008 03:34 PM
boomslang
22
Jun 8, 2005 10:55 AM
Norcalstoppy
Oct 15, 2002 01:29 PM
