CAM not turning
Old Apr 2, 2005 | 12:18 PM
user 98292739's Avatar
Default CAM not turning
so i got a rebuilt z6 head here.....and i can tturn the cam to TDC. I am thinking this isnt turnable due to the new springs pushing up on it and how the whole thing is bone dry basically cept for some surface oil. now do i take the rocker assembly off place it TDC lube up the cam and everything and bolt it back together? and before i start the motor and put the valve cover on should i dump some motor oil on top of everything to prevent start up metal to metal?
Old Apr 2, 2005 | 01:04 PM
Mach69's Avatar
Default Re: CAM not turning (LoCoReX)
I hope your cam isn't broken.
You want to set the block and head to TDC when you put the head back on. If you turn the cam by hand (wrench) it doesn't matter if there is oil in there. You aren't going to be turning it fast enough to do damage ( I think ). Turn the cam over to TDC, then take out the rocker assembly and lube the cam area up nice, with engine oil (or if you got a new cam it might of came with some lube, otherwise engine oil). Pour it over where the cam rotates in the head assembly and over the cam lobes. That should be enough oil. Make sure before you tighten the rocker assembly back on and that all the valves are in the TDC position otherwise you WILL break the camshaft. I had one of mine break on me (not fun to waste 280 bux). Also torque everything down to spec (Helm's).
Old Apr 2, 2005 | 02:42 PM
what do you mean by broken? it better not be...its brand new....
h22ej8
Jun 7, 2021 10:28 AM
abusedvtec
Jul 27, 2009 11:51 AM
walker93
Jul 5, 2009 06:43 PM
nominous
Dec 12, 2008 09:53 AM
