getting itr cams (b16) what power do they make from 8200-8500 rpm
Old Apr 1, 2005 | 08:14 PM
B18C GSR CIVIC's Avatar
Default getting itr cams (b16) what power do they make from 8200-8500 rpm
The reason I ask. Well i was supposed to get bc3+ but that got fucked up so I am just gonna get some itr cams.
Okay, I had ordered springs and reatiners for my bc3+ as I know I planned on reving them till at least 8500 rpm as they make good power till then but now that I will be getting itr cams I can easily keep the stock redline and use my stock valve train as I know a b16 can see 8200 all day with ease with itr/ctr cams as I did it years ago b4 the yellow bomb was turbo.
So question is, what power do the itr cams make up top, from say 8000-8500 rpm cause if I keep stock valvetrain not only do i save cash for not buying springs and retainers but i save money for not having to install that crap as well.
mods,
intake
4 into 1
thermal exhaust
intake cam gear ava, installed when cams go in
hondata, will be installed b4 dyno tune
fpr
..thats it for now
thanks guys!
Kenny
Old Apr 1, 2005 | 08:42 PM
JDMlyfestyle's Avatar
mine made power up until 8200 and then it dropped off. But who really knows cause i was on a blown headgasket on the dyno
Old Apr 2, 2005 | 05:01 AM
Default Re: (JDMlyfestyle)
thank you for the one reply but jesus, Im sure therhe are over 3,000 members on here with a b16 and itr cams that havew a dyno with simple bolt on's and hondata at that. Just curious if the gains threw that small window are worthy of all that extra cash for springs and retainers.
Old Apr 2, 2005 | 10:35 AM
Default Re: getting itr cams (b16) what power do they make from 8200-8500 rpm (B18C GSR CIVIC)
more opions
Old Apr 2, 2005 | 10:50 AM
red_crx's Avatar
if your turbo, im pretty sure you will see power past 8200
Old Apr 2, 2005 | 10:59 AM
Default Re: (red_crx)
haha, this is for my n/a civic, not my fully built beast!
Anyways after a good hour of searchig I found a few dyno's with itr cam and people reving till 8500-8600 and really the cuve is flat if not just starting to fall off. SO imo, its probably more worth wile to stay stock valve train and keep rev limit to 8200 with hondata!
Old Apr 2, 2005 | 11:02 AM
blackANESE's Avatar
Here's my b16 dyno from a couple years ago
Sorry for the crappy pic but power starts falling off at 8300
Old Apr 2, 2005 | 11:04 AM
Default Re: getting itr cams (blackANESE)
was that with itr cams bro, thanks Kenny!
still good numbers for a b16!
Old Apr 2, 2005 | 11:11 AM
blackANESE's Avatar
Default Re: getting itr cams (B18C GSR CIVIC)
<TABLE WIDTH="90%" CELLSPACING=0 CELLPADDING=0 ALIGN=CENTER><TR><TD>Quote, originally posted by B18C GSR CIVIC &raquo;</TD></TR><TR><TD CLASS="quote">was that with itr cams bro, thanks Kenny!
still good numbers for a b16!</TD></TR></TABLE>
Yeah it was with CTR cams. I was stoked b/c it was a stock block and bolt-ons basically
Old Apr 2, 2005 | 05:03 PM
red_crx's Avatar
o may bad, if its for an n/a car with bolt ons its going to be kind of hard to get power past 8200rpm
Old Apr 2, 2005 | 05:22 PM
EG6R's Avatar
My B16 with ITR cams made power until 8000. Everything downhill after that.
Old Apr 2, 2005 | 06:09 PM
Default Re: getting itr cams (EG6R)
you guys are awsome. If you evefr need jdm bling, i can always hook you up and im turbo smart to
thanks
Kenny!
Old Apr 2, 2005 | 08:21 PM
UncleD's Avatar
I personally have a B16B in my car, and in stock form the b16B makes power up until redline. It never falls off.......granted it has a ported head, but my rev limiter bounces around 8,700 with the stock ecu. You can run the cams with the stock b16 valvesprings, both of my roomates have dropped ITR cams in they're b16's and both of them have had <U>noticeable</U> power gains. THey pull MUCH harder in 3rd gear for sure....imo they are one the most cost efective upgrades you can do!
Old Apr 2, 2005 | 08:25 PM
TrnsferErr's Avatar
my ctr cams stopped making power after 8200, they just started to drop after that, i kno its not itr but i heard they are very similar.
Old Apr 2, 2005 | 08:35 PM
SiKnezzALLmotor's Avatar
Default Re: (TrnsferErr)
more dyno graphs please
Old Apr 2, 2005 | 08:44 PM
EFB16ACRX
Guest
Posts: n/a
Default Re: (SiKnezzALLmotor)
i have one with ctr cams, but its not much use to you, my power drops off at 6800 rpm, shitty, and i mean SHITTY chipped ecu
keep in mind these are mph, not rpm at the bottom
not much help, but its something. I also have, 4-2-1 header, cai, vafc, chipped ecu, and ctr pistons.
Old Apr 2, 2005 | 09:01 PM
kermit97's Avatar
hey guys im in the same page still debating ctr or itr cams but in used parts on my b16a 2 so wats good cams out there for a good buck
Old Jun 16, 2005 | 11:50 AM
Colt Seavers's Avatar
I have ITR cam in my b16 , and it feels like it stops making power at around 8,300.
Where is the stock itr's vtec change over at. I have mine set at 5,500 do you think that it's to low.
A.R
Sep 23, 2009 05:00 PM
paul8ex
Oct 3, 2007 09:05 PM
patdemps
Sep 18, 2003 06:57 PM
cr00klyn718
Mar 17, 2002 02:39 PM
Dirty GS-R
Oct 12, 2001 02:06 PM
