my build up
alright heres my build up
b16 head with
port & polish & a 3 angle valve job
skunk2 retaners, dual valve springs & ferrea valves
skunk2 stage 3 cams with adjustable cam gears
skunk2 intake mani
b18c1 bottom end pretty much stock exept for some ctr pistons
and i'm running a p28 set at type r specs
do u guys think this is a good setup that will put out some serious power?
and also do u guys think it can be a daily driver?
thanx in advance
b16 head with
skunk2 intake mani
thanx in advance
which one should i go with? hondata s200 or neptune managment? also can this set up put out some powerful hp & torque to the wheels? and can it be a daily driver. thanx for replying
should make nice power similar set up that im doin but im using a gsr head and m24x's probobly, and no 3angle valve job and stock valves.... i would say get hondata but up to you.. im using uberdata ... anything is good for a daily driver after it is tunned right and you get used to it after a lil
if your goin to be using the ctr pistons then deffentaly go with like 93 octane if you have it around cause your sompression is goin to be high.. almost 13:1 with a b16 head... im goin to be using 94 since i have it around the corner by my house
Agustine Reyes
10
Oct 14, 2017 02:02 PM
gsrhatch2356
Texas -OK -LA (Sales)
34
Dec 24, 2010 12:09 AM
keepinitrehaal
Feb 18, 2010 07:48 PM
mjfubar101
14
Jun 30, 2007 08:29 PM
