How to: Lube Master/Slave Cylinder, Throwout Bearing, Clutch Fork
Old Apr 1, 2005 | 05:27 PM
xunkn0vvnx's Avatar
Default How to: Lube Master/Slave Cylinder, Throwout Bearing, Clutch Fork
In an attempt to ride my integra of Clutch Squeak I am taking the advice of fellow HT'ers and plan on lubing the master/slave cylinder, throwout bearing, and clutch fork. I have a haynes manual but do not find it very useful. How would I go about completing these tasks ?? I have already WD 40'd the clutch springs so that is not the problem.
Here are some pictures of under the dash, from up top of the engine bay, and downlow of the engine bay. Can someone point out what is what ?? and what i need to lube ?? Also if disassembly is needed.
Top of engine bay:
Beneath Car:
Under Dash:
Modified by xunkn0vvnx at 9:42 PM 4/1/2005
Old Apr 1, 2005 | 06:18 PM
projectTeG's Avatar
HOLY resize the pics BATMAN!!!!!! also, i think you can grease the pivot that the arm rests on
Old Apr 1, 2005 | 07:06 PM
Dan GSR's Avatar
Default Re: (projectTeG)
BAN !!
Old Apr 2, 2005 | 09:22 AM
xunkn0vvnx's Avatar
where is this pivot at ??
Old Apr 2, 2005 | 10:26 AM
projectTeG's Avatar
do you have a manual for your car....if you dont id suggest the helms of at least a haynes...the pivot is where the slave cylinder is
Old Apr 4, 2005 | 12:50 AM
xunkn0vvnx's Avatar
Default Re: How to: Lube Master/Slave Cylinder, Throwout Bearing, Clutch Fork (xunkn0vvnx)
how exactly do i access this point ?
Javelin
Sep 29, 2015 07:17 PM
nothome17
Acura TSX
Sep 30, 2010 11:06 AM
xunkn0vvnx
Apr 4, 2005 06:30 PM
junglistgsr
Dec 7, 2001 10:27 AM
