How do i get the speed sensor out??? Trying to change clutch.
Old Apr 1, 2005 | 08:02 AM
Hypertek99's Avatar
Default How do i get the speed sensor out??? Trying to change clutch.
I can't get it out.
Old Apr 1, 2005 | 08:05 AM
EP3_05's Avatar
Default Re: How do i get the speed sensor out??? Trying to change clutch. (Hypertek99)
There is a little "pinch clip" holding it in the trans. Remove the clip and pull the vss cable out.
Old Apr 1, 2005 | 08:08 AM
Hypertek99's Avatar
Are you talking about the clip that a 10mm screw holds in?? I took out the 10mm and the clip alreay. Do i just pull real hard on the sensor. I don't want to break it.
Old Apr 1, 2005 | 08:10 AM
EP3_05's Avatar
No, it is just a clip that slides into a slot on the cable to hold it into the trans.
It is number 13 in this pic from http://www.hondaautomotiveparts.com
Old Apr 1, 2005 | 08:13 AM
Hypertek99's Avatar
Ok i think i see what your talking about. Thanks
Old Apr 1, 2005 | 09:20 AM
kaoss_11's Avatar
B A N N E D
make sure its in neutral
89ED
Feb 26, 2018 10:47 AM
SlimJim25
Apr 14, 2013 08:25 AM
rolledthatho
15
Jan 26, 2011 07:52 PM
98bucket
Sep 10, 2010 08:51 AM
Channooo
Aug 12, 2009 01:50 PM
