Braking Noise/Problems
Old Apr 1, 2005 | 01:02 AM
lo0nY's Avatar
Default Braking Noise/Problems
have a 93 Civic Coupe...recently did a 5 lug conversion....and i had a noise coming from the front driver side area...i thought it was the breaks, so i went a head and bought new pads and rotors from acura.....replace them....it was fine for about 10 minutes, and the noise came back.....i then started to get crazy road noise around 60mph-70mph, anything above that or below that i don't hear a thing.....change out new wheel bearings......still got the problem it's getting to the point where i don't know what else to do....my only other thought it could be is the axle? could i be correct?
PS. these two noises, coming from the same place, first is the noise like squealing and the second sounds like bad bearings...
Old Apr 1, 2005 | 08:23 PM
lo0nY's Avatar
Default Re: Braking Noise/Problems (lo0nY)
bump
Old Apr 3, 2005 | 04:37 PM
lo0nY's Avatar
bmp
Old Apr 3, 2005 | 05:13 PM
killaj12's Avatar
Default Re: (lo0nY)
bump
sorry, i cant help u cuz im a noob
got a noob question tho, what does bad bearings sound like ?
i have noises and vibrations i cant figure out too,and someone mentioned it could be a bad bearing?
Old Apr 4, 2005 | 07:37 AM
lo0nY's Avatar
Default Re: (killaj12)
loud noise while driving.....
Old Apr 4, 2005 | 08:08 AM
2lua's Avatar
Default Re: (lo0nY)
<TABLE WIDTH="90%" CELLSPACING=0 CELLPADDING=0 ALIGN=CENTER><TR><TD>Quote, originally posted by lo0nY &raquo;</TD></TR><TR><TD CLASS="quote">loud noise while driving.....</TD></TR></TABLE>
in gear or out of gear? while turning or straight? is the dirt shield bent?
jack the car up with jack stand. grab the tire with both hands move the tire left right see if the tire got any play. if it does. you might need new wheel bearing. or with the car secure on the jack stand have some one start your car and put it in gear (simulate driving), while some one else can check for noises. do this at your own risk
Old Apr 4, 2005 | 09:47 AM
376R's Avatar
Default Re: (lo0nY)
<TABLE WIDTH="90%" CELLSPACING=0 CELLPADDING=0 ALIGN=CENTER><TR><TD>Quote, originally posted by lo0nY &raquo;</TD></TR><TR><TD CLASS="quote">loud noise while driving.....</TD></TR></TABLE> I got the same problem !!!!!!!!!!!
its driving me insane . accept its when im going anywhere from 25-50mph. anything under or over that i cant hear it. its started happening when i got my new itr tranny installed. but the tranny is fine. and only 28k on it. when i push the clutch in cant really hear the noise at all. I work at honda, ive had the mech. drive my car nothing is wrong with the tranny. it sounds like its from the front. but then the back too. so i dont know but its driving me crazy. its loudest going about 40mph in 5th gear. whoa. someone help us out bump
Old Apr 4, 2005 | 09:02 PM
lo0nY's Avatar
Default Re: (klubhed1)
my noise is just from braking......
kenskii
Jul 8, 2014 08:33 PM
kcari
Suspension & Brakes
Oct 28, 2009 12:30 PM
MatrixShark
Mar 23, 2007 01:33 PM
_RedRiceR_
Jun 19, 2006 12:59 AM
DC5_R
Jun 30, 2003 03:35 AM
