Z6 swapped CRX Si....Couple questions.
Old Mar 31, 2005 | 10:24 PM
GarettBrowning's Avatar
Default Z6 swapped CRX Si....Couple questions.
I got the engine harness but do you have to have the z6 interior harness too?
Old Apr 1, 2005 | 02:59 PM
crx_of_fury's Avatar
Default Re: Z6 swapped CRX Si....Couple questions. (eg62come)
if you use your intake, fuel rail, and injectors, your stock si harness should work, then all you have to do is run a wire for vtec if you use a different ecu, or get a vtec controller
Old Apr 1, 2005 | 05:45 PM
NikoZai's Avatar
Default Re: Z6 swapped CRX Si....Couple questions. (crx_of_fury)
You want to convert your Si to OBD1 and use the correct OBD1 ECU for it.
http://www.rywire.com/sitodvtec.shtml
Under no circumstances do you:
A. Use the complete Z6 wiring harness in your CRX engine bay
B. Use both the cabin harness and engine harness.
Old Apr 26, 2005 | 03:17 PM
Default Re: Z6 swapped CRX Si....Couple questions. (NikoZai)
How hard is it to hook a vtec controller up?
AlfieRoach
Nov 14, 2010 12:02 AM
90Rexx
Sep 15, 2010 10:47 AM
Aquafina
May 18, 2007 11:01 AM
memorybox
Sep 26, 2006 01:55 PM
hatchinprogress
10
Jul 13, 2005 04:05 PM
