wtf could this noise be???!?!?!?
Old Mar 31, 2005 | 10:17 PM
d16y8EL's Avatar
Default wtf could this noise be???!?!?!?
it only happens when i turn right at anything faster than 10km/hr its like a scraping noise like my muffler is scraping on the ground. but its not. theres nothing hitting when i have my wheel turned either. i think its my axle bearing or something. any help would be appreciated so i dont have to have a mechanic **** me over.
Old Mar 31, 2005 | 10:37 PM
Andres-eh2's Avatar
What have you done to the car recently?
How low is your car?
What size rims and tires?
Old Apr 1, 2005 | 12:05 PM
95singlecamvtec's Avatar
Default Re: wtf could this noise be???!?!?!? (d16y8EL)
My car made a similar noise, i tore my axle boot and all grease leaked out and the bearings just gave out. Good luck, hope this will help.
Old Apr 1, 2005 | 12:18 PM
NaVamous's Avatar
Could be your CV joint....probably torn, needs replacement.
Old Apr 1, 2005 | 01:48 PM
sik_sol's Avatar
B A N N E D
check the inside of your wheels to see if there is any grease on the inside from it being torn....if there is then your axle needs replacement...its pretty simple to fix tho...
Old Apr 1, 2005 | 04:07 PM
EG1.8cT68's Avatar
It could be several things, start with your rotor sheild make sure it isn't rubbing against the rotor, then check your pads, then inspect your CV boot, and finally see if your fender liner is getting rubbed by the wheel.
Old Apr 1, 2005 | 04:14 PM
HitEm'Up's Avatar
CV boot torn is usually the common problem
Steve LeB
Oct 28, 2011 11:58 PM
BOOSTED_JDM_DB8
Dec 26, 2007 12:15 PM
WRTEG
Aug 18, 2004 02:15 PM
GReddy SI
12
Jul 17, 2003 04:07 AM
Stellar1
25
Mar 11, 2003 05:35 PM
