Best way to get old intake manifold gasket off?
Old Jan 27, 2002 | 10:44 AM
91DA9's Avatar
Default Best way to get old intake manifold gasket off?
Hi. I am working on a '92 GS-R. We have taken the Intake manifold off to replace the gasket. It has the original one on it and it has stuck to the manifold and a little bit on the head. I was just going to use a screwdriver or razor blade to scarpe it off and then use gasoling or Isopropyl alcohol to remove any leftover gasket. Is this a good idea? or will the screwdriver scratch the manifold too much?
Thanks
nate
Old Jan 27, 2002 | 11:57 AM
B18CRacer's Avatar
Default Re: Best way to get old intake manifold gasket off? (94IntegraGSR-OVR)
soak that end in alcohol for a couple of days...it should easily come off when its done soaking. I wouldnt use a screw and hack that thing off because it will create a lot of scratches unless you dont care.
Old Jan 27, 2002 | 12:03 PM
non-VTEC's Avatar
use razor blades scrap the gasket off......it should take you about 30min to clean the surface.....
Old Jan 27, 2002 | 01:25 PM
DB2-R81's Avatar
25 Year Member
Default Re: Best way to get old intake manifold gasket off? (non-VTEC)
Go to the auto parts store and get some of these, way quicker and will not damage your head and manifold.
http://www.sa-motorsports.com/cat/p12.htm
Old Jan 27, 2002 | 01:32 PM
boosted1993fd's Avatar
They also have a type of spray you can buy in a can that will eat away the old gasket and not harm the metal on the intake manifold or the head. You can probably pick it up at your local auto parts store. I have a can of it in my garage that is made by Permatex and is in a blue can...see if you can find it...it works real well. Takes about 10 to 15 minutes and requires minimal effort.
Old Jan 27, 2002 | 03:13 PM
primoEF's Avatar
it is called "gasket remover" in a blue spay can, also you can use a sanding disc that is designed for removing gasket
aryiman98civic
Feb 24, 2007 07:02 PM
GsrVtec
Sep 13, 2006 09:53 AM
dualknuttz1
Jan 23, 2004 08:37 PM
The Toecutter
Jul 17, 2002 03:55 PM
