How often do you guys empty your catch can?
Old Mar 31, 2005 | 06:56 PM
Toadfart's Avatar
Default How often do you guys empty your catch can?
I bypassed the black box behind the block and routed it to a catch can, then to the PCV. It fills up pretty fast. As in half a quart every hundred miles or so. How often do you guys empty?
Dan
Old Mar 31, 2005 | 07:11 PM
Code Blue's Avatar
Default Re: How often do you guys empty your catch can? (Toadfart)
hmm, that seems like alot man....have you checked your compression? you might be getting alot of blowby from spent rings.
Old Mar 31, 2005 | 07:16 PM
Toadfart's Avatar
Default Re: How often do you guys empty your catch can? (Code Blue)
Would blow by make it into the catch can?
Old Mar 31, 2005 | 09:42 PM
ernald711's Avatar
<TABLE WIDTH="90%" CELLSPACING=0 CELLPADDING=0 ALIGN=CENTER><TR><TD>Quote, originally posted by Toadfart &raquo;</TD></TR><TR><TD CLASS="quote">Would blow by make it into the catch can?
no, blowby is a problem where part of your combustion gases escapes in between the cylinder wall and piston due to bad ring seals set by your rings. you'll ususally get this when your combustion ring (the top ring) is old and doesn't seat properlly. Or if you have a bent rod or something where it's (the rod) is pushing and pulling the piston at and angle fukk'n up your cylinder walls, but that would be worst case senario type ****. like mentioned in the previous post you'd lose compression because of this and your oil will be black as hell, more than usual. sorry for the off topic answer, or if you already knew this...
and no i don't think it would because of the way the block is designed from the cylinder wall down.
Old Apr 1, 2005 | 02:21 AM
greasemonkee's Avatar
Default Re: How often do you guys empty your catch can? (ernald711)
Were you actually using (or burning ) that much oil before the catch can addition?
If so, you might consider some internal repair.
Old Apr 1, 2005 | 06:01 AM
Backk InTheDA's Avatar
I hate everything
<TABLE WIDTH="90%" CELLSPACING=0 CELLPADDING=0 ALIGN=CENTER><TR><TD>Quote, originally posted by ernald711 &raquo;</TD></TR><TR><TD CLASS="quote">if you have a bent rod or something</TD></TR></TABLE>
Thats never good.
iTR
r3v da t3g
Oct 30, 2007 04:50 PM
koolaid3246
May 2, 2006 06:25 AM
Sport_Injected
Oct 20, 2004 02:54 PM
Jmorin
May 11, 2004 08:57 PM
Ryan C
Dec 8, 2003 02:31 PM
