Throttle body size for d16z6
Old Mar 31, 2005 | 06:41 PM
95singlecamvtec's Avatar
Default Throttle body size for d16z6
I have done some research, but i am still unsure what make and size throttle body i should get. I have an aem short ram intake, skunk2 intake manifold, dc 4-2-1 headers, 2.25'' exhaust piping no cat, magnaflow exhaust, msd 6al ignition, msd blater 3 coil, accel 8mm wires, act stage 2 clutch, and a fidanza 7lb flywheel. I have a vtec controller and skunk2 valves and springs that i need to install, i am not sure which cam im going to buy ethier a stage 1 or stage 2. I would appreciate all the info i can get thanks.
Old Mar 31, 2005 | 06:45 PM
civictildeath's Avatar
Default Re: Throttle body size for d16z6 (95singlecamvtec)
if you go bigger than the opening of the intake manifold you have to bore the opening out to match the throttle body.
i would go with the 62mm from the integra type r b18c5 engine and stay with honda equiptment
http://www.knology.net/~jediklc/tbsize.htm
Old Mar 31, 2005 | 07:50 PM
blackeg's Avatar
Default Re: Throttle body size for d16z6 (civictildeath)
just get an oem b series tb. i put a gsr tb on my old z6. thats up from 56mm to 60mm. in my opinion, its not really worth shelling out a lot of money for an aftermarket tb
Old Mar 31, 2005 | 08:05 PM
SOHCmaster's Avatar
Just dont buy a Skunk2 tb, so far they all have major issues with sticking
Old Mar 31, 2005 | 09:12 PM
Default Re: Throttle body size for d16z6 (blackeg)
<TABLE WIDTH="90%" CELLSPACING=0 CELLPADDING=0 ALIGN=CENTER><TR><TD>Quote, originally posted by blackeg &raquo;</TD></TR><TR><TD CLASS="quote">just get an oem b series tb. i put a gsr tb on my old z6. thats up from 56mm to 60mm. in my opinion, its not really worth shelling out a lot of money for an aftermarket tb</TD></TR></TABLE>
Could you feel the difference after you installed the gsr tb?
recon23
Oct 28, 2007 06:50 PM
95bkeg
May 13, 2006 05:39 PM
bryant382
Sep 14, 2003 04:14 AM
B18C2_sedan
Dec 7, 2002 02:40 PM
