can 17x8 +35 offset wheels fit a 5th gen
will 17x8 +35 offset fit my 96 accord coupe with 2 1/4 drop? Also would I have to roll the fenders to prevent rubing? Whats kind of widths an offsets are you running?
usual offset for wheels on an accord is somewhere between +40 and +45 offset.
96 jdm itr wheels are +38 offset, and require either a 5 mm spacer, or shaving of the caliper in order to fit. but, they're 15 inches, so hitting the fender is not a problem.
a 17 x 8 wheel is pushing the limits of width on an accord, and the low offset will require the use of a spacer.... they will likely hit the fender.
steps of fender alteration:
removing fender well trim
pulling the fenders
rolling the fenders
cutting the fenders.
you may be able to get away with simply pulling the fenders.
fender rolling diy
synopsis: you won't be able to slap the rims on and call it a day... at the minimum you'll need a spacer and removal of the fender well trime... at most, you'll need to pull, roll, and possibly cut your fenders.
pulling the fenders
rolling the fenders
fender rolling diy
ActiveAero
Feb 12, 2005 02:41 PM
