PSI for 204/45-16
Old Mar 31, 2005 | 04:29 PM
RDSDC2's Avatar
Default PSI for 204/45-16
205/45-16
what should the psi be set at for daily driver?
Old Apr 1, 2005 | 06:13 AM
dFreezy's Avatar
Default Re: PSI for 204/45-16 (ReddragonDC2)
check the chart on the inside on your door sill...i believe the oem spec is 35 psi front, 33 psi rear for integras
Old Apr 1, 2005 | 07:08 AM
kineticgsr's Avatar
<TABLE WIDTH="90%" CELLSPACING=0 CELLPADDING=0 ALIGN=CENTER><TR><TD>Quote, originally posted by ReddragonDC2 &raquo;</TD></TR><TR><TD CLASS="quote">205/45-16
what should the psi be set at for daily driver?</TD></TR></TABLE>
the factory specs are a great staring point...then adjust for driving style
and conditions
Old Apr 1, 2005 | 02:16 PM
RDSDC2's Avatar
Default Re: PSI for 204/45-16 (kineticgsr)
so the 205/45-16 shouldn't be too different from the 195/60-14 factory psi?
Old Apr 4, 2005 | 07:07 AM
JimBlake's Avatar
Default Re: PSI for 204/45-16 (dFreezy)
<TABLE WIDTH="90%" CELLSPACING=0 CELLPADDING=0 ALIGN=CENTER><TR><TD>Quote, originally posted by dFreezy &raquo;</TD></TR><TR><TD CLASS="quote">check the chart on the inside on your door sill...i believe the oem spec is 35 psi front, 33 psi rear for integras</TD></TR></TABLE>That's the spec for a GSR. If your stockers are 195/60-14 then it's an LS & your door sticker probably says 31 or 32 all around. The GSR pressures (35/33) will probably be a better starting point for 205/40-16 tires.
Old Apr 4, 2005 | 10:27 AM
dFreezy's Avatar
<TABLE WIDTH="90%" CELLSPACING=0 CELLPADDING=0 ALIGN=CENTER><TR><TD>Quote, originally posted by ReddragonDC2 &raquo;</TD></TR><TR><TD CLASS="quote">so the 205/45-16 shouldn't be too different from the 195/60-14 factory psi?</TD></TR></TABLE>nope. should be set to whatever your door sill says.
Old Apr 4, 2005 | 01:13 PM
RDSDC2's Avatar
Default Re: PSI for 204/45-16 (JimBlake)
<TABLE WIDTH="90%" CELLSPACING=0 CELLPADDING=0 ALIGN=CENTER><TR><TD>Quote, originally posted by JimBlake &raquo;</TD></TR><TR><TD CLASS="quote">That's the spec for a GSR. If your stockers are 195/60-14 then it's an LS & your door sticker probably says 31 or 32 all around. The GSR pressures (35/33) will probably be a better starting point for 205/40-16 tires.
they are actually 205/45-16, but thanks to all who replied
k24-Aeight
Apr 2, 2008 08:20 PM
..::91TEG-G2::..
Nov 24, 2007 07:45 AM
BoOsTiN Dc2
Aug 6, 2005 09:55 PM
importdude2000
Nov 20, 2004 08:39 AM
JimmyAtlantis
26
Jun 5, 2004 02:44 PM
