To those with AN-R Header...
Old Mar 31, 2005 | 02:57 PM
jdm_ef9's Avatar
Default To those with AN-R Header...
For those who are running an AN-R header(either standard or compact)... what did everybody do for a flange to connect header to testpipe? As you know the AN-R doesnt come with a flange. I got a stainless compact header... and I'm runnin full stainless exhaust. I cannot find a 2.5" 2-bolt stainless flange anywhere. I can find 3-bolt ones all day long. I would like to still use the 2-bolt so I can still disconnect it from the testpipe. Anyone have any ideas??? If anyone has pics of their setup too that would be great. Thanks!!!
Old Mar 31, 2005 | 03:02 PM
Eclypz's Avatar
http://www.kteller.com/store/p...d/578
i welded a flex pipe onto it and connect it to a test pipe with a 2.5" 2-bolt flange.
Old Mar 31, 2005 | 06:36 PM
jdm_ef9's Avatar
Default Re: (Eclypz)
i dont think that the flange from kteller is stainless... can you weld mild steel to stainless? dis-advantages? the flex isnt a bad idea!
Old Mar 31, 2005 | 07:09 PM
JDMlyfestyle's Avatar
Im running a flex pipe and its connected to my RSR GTII exhaust. it pretty much bolted right up the guy kinda put the flange on the flex pipe a lil cockeye'd but i cant complain. Flex pipe and flange plus labor $25
Old Mar 31, 2005 | 07:45 PM
Innovation's Avatar
Default Re: To those with AN-R Header... (jdm_ef9)
Flex pipe is a must
Old Mar 31, 2005 | 08:03 PM
flex pipe is not a must. i rolled around with the header for over a year and a half and over 80 passes at the track. not a single crack. i got the flex pipe since im gettin traction bars and Some stiff hasport mounts.
Old Mar 31, 2005 | 09:45 PM
Eclypz's Avatar
Default Re: (jdm_ef9)
<TABLE WIDTH="90%" CELLSPACING=0 CELLPADDING=0 ALIGN=CENTER><TR><TD>Quote, originally posted by jdm_ef9 &raquo;</TD></TR><TR><TD CLASS="quote">i dont think that the flange from kteller is stainless... can you weld mild steel to stainless? dis-advantages? the flex isnt a bad idea!</TD></TR></TABLE>
sorry...i overlooked the SS part.
Old Mar 31, 2005 | 10:12 PM
ShaunRR's Avatar
HT White Ops
Community Builder
Default Re: To those with AN-R Header... (Innovation)
<TABLE WIDTH="90%" CELLSPACING=0 CELLPADDING=0 ALIGN=CENTER><TR><TD>Quote, originally posted by Innovation &raquo;</TD></TR><TR><TD CLASS="quote">Flex pipe is a must</TD></TR></TABLE>
Old Mar 31, 2005 | 11:47 PM
RMF
Guest
Posts: n/a
<TABLE WIDTH="90%" CELLSPACING=0 CELLPADDING=0 ALIGN=CENTER><TR><TD>Quote, originally posted by Innovation &raquo;</TD></TR><TR><TD CLASS="quote">Flex pipe is a must</TD></TR></TABLE><TABLE WIDTH="90%" CELLSPACING=0 CELLPADDING=0 ALIGN=CENTER><TR><TD>Quote, originally posted by Innovation &raquo;</TD></TR><TR><TD CLASS="quote">Flex pipe is a must</TD></TR></TABLE><TABLE WIDTH="90%" CELLSPACING=0 CELLPADDING=0 ALIGN=CENTER><TR><TD>Quote, originally posted by Innovation &raquo;</TD></TR><TR><TD CLASS="quote">Flex pipe is a must</TD></TR></TABLE><TABLE WIDTH="90%" CELLSPACING=0 CELLPADDING=0 ALIGN=CENTER><TR><TD>Quote, originally posted by Innovation &raquo;</TD></TR><TR><TD CLASS="quote">Flex pipe is a must</TD></TR></TABLE>
I'm always one up on you.S.K. HA HA
Its ok to weld steel to S.S..And the flange on your header is steel.also.
Old Apr 1, 2005 | 12:01 AM
2k.civic.si's Avatar
Default Re: To those with AN-R Header... (RMF)
mines directly bolted to my exhaust with no flex pipe =P
no cracking here
Old Apr 1, 2005 | 04:20 AM
jdm_ef9's Avatar
Default Re: To those with AN-R Header... (2k.civic.si)
i guess maybe i should wait till i actually recieve the header(anytime now!!!), and see if the flex will be needed. id rather not run it unless i have to. thanks for the opinions... keep them coming!!!
Old Apr 1, 2005 | 07:05 AM
97L-esVeeTeg's Avatar
I think its a safe bet to say that if RMF says you should use one its probably a good idea, especially when referring to these headers of course.
Old Apr 3, 2005 | 09:52 PM
Default Re: To those with AN-R Header... (97L-esVeeTeg)
hehe...ya he pm'ed me about them....what i left out is im running aftermarket motor mounts and the engine moves very little....only way you can run it without flex pipe is if you have solid motor mounts so there is no flex
Old Apr 4, 2005 | 03:58 AM
jdm_ef9's Avatar
<TABLE WIDTH="90%" CELLSPACING=0 CELLPADDING=0 ALIGN=CENTER><TR><TD>Quote, originally posted by 2k.civic.si &raquo;</TD></TR><TR><TD CLASS="quote">hehe...ya he pm'ed me about them....what i left out is im running aftermarket motor mounts and the engine moves very little....only way you can run it without flex pipe is if you have solid motor mounts so there is no flex </TD></TR></TABLE>
im runnin hasport billet b-series(efb1) mounts. i have NO engine flex at all. i guess i should be fine then? thanks!
Old Apr 4, 2005 | 04:08 AM
ceLtic*
Guest
Posts: n/a
flex pipe y0
Old Apr 4, 2005 | 05:26 AM
NA.GEORGE's Avatar
Default Re: To those with AN-R Header... (ceLtic!)
wats the difference between the street collector and the merge collector with the an-r headers
i kno theres a big difference in price i was just wondering the difference i was goin to go with the merge but before i do i wanna kno the difference between the 2
Old Apr 4, 2005 | 05:58 AM
Bradstard's Avatar
I have a 3" collector on my AN-R header. I had a 3" flex pipe welded on to the downpipe of the header. I am also running a Thermal 3" exhaust which came with a weld on flange that I welded on the flex pipe. It all bolts together very nicely. I'll try and post some pics later today.
Old Apr 4, 2005 | 11:01 AM
rodrez.'s Avatar
I picked up a stainless flange from a local muffler shop, and had a friend weld it on for me. (My ANR is the stainless version).
Also, many people don't use flex pipes with their ANR's, but I chose to use one, because of the stiff HA Sport mounts.
Old Apr 4, 2005 | 03:54 PM
jdm_ef9's Avatar
Default Re: To those with AN-R Header... (Fat Bradstard)
<TABLE WIDTH="90%" CELLSPACING=0 CELLPADDING=0 ALIGN=CENTER><TR><TD>Quote, originally posted by Fat Bradstard &raquo;</TD></TR><TR><TD CLASS="quote">I have a 3" collector on my AN-R header. I had a 3" flex pipe welded on to the downpipe of the header. I am also running a Thermal 3" exhaust which came with a weld on flange that I welded on the flex pipe. It all bolts together very nicely. I'll try and post some pics later today.</TD></TR></TABLE>
whats the stuff you used to clean your header before install... you mentioned it in one of your other posts? thanks!
DA9nEF9
Welding / Fabrication
Oct 1, 2014 07:03 PM
blackbettyek
Mar 29, 2010 07:18 PM
idrivealude
Sep 15, 2008 03:28 PM
polishedturd
Jan 10, 2008 12:56 PM
ATS*Mark
Nov 25, 2005 01:31 PM
