Shaking while turning right/ going straight?
Ive got a B16 in a CRX and i just recently bought brand new axles for both sides(had the JDM axles in before) and now i have a really bad shaking/vibration when i make a right turn/going straight, but when I make left turn, its fine. Its definatley coming form the left side. The car had an alignment done yesterday. Its a Y1 tranny. Any ideas? Ive heard that I might need to remove a dust ring? Where exactly would it be located/how do i remove it?
I just had this problem on my B16 CR-X which axles did you get, because if you had the JDM axles in then when you replace them you need the JDM axles, if you replaced them with 90 integra axles then you need a 90 intermediate shaft, I had the same problem change the intermediate shaft and the problem will be gone
-=TWITCH=-
16
Apr 6, 2002 09:22 PM
