Installed Portable DVD Player in 95 si but no volume? PLEASE HELP!
Old Mar 31, 2005 | 09:18 AM
slammedef06's Avatar
Default Installed Portable DVD Player in 95 si but no volume? PLEASE HELP!
i have a pioneer deh p7300 deck installed in my 95 si, i just installed a little portable dvd player in the car...i used the adaptor that goes from rca's to an earphone plug...i plugged the rca's into the a/v jacks in the back of the deck and the other end into the 'audio' hole of the portable dvd player, then i changed my deck to AUX and you can bearly hear the sound. so i tried putting the earphone end into the 'earphone' hole on the dvd player, still nothing. i even tried to plug the rca's to the amp in my car but still nothing. what do i have to do to get sound? there are other rca inputs available on my deck like 'hands free' and 'telephone' should i try using these or what? thanks for any help!
Old Mar 31, 2005 | 09:34 AM
Matt_ks_001's Avatar
Default Re: Installed Portable DVD Player in 95 si but no volume? PLEASE HELP! (slammedef06)
i have the same problem??? <bump>
Old Mar 31, 2005 | 09:54 AM
Default Re: Installed Portable DVD Player in 95 si but no volume? PLEASE HELP! (Matt_ks_001)
yeah, i just heard that you can use an fm modulator but i'd rather it play through the 'aux' source. anyone have suggestions?
Old Mar 31, 2005 | 04:13 PM
anyone? how can we get sound from the portable dvd player through the car speakers?
Old Mar 31, 2005 | 04:21 PM
fcm's Avatar
fcm
Old Fart
<TABLE WIDTH="90%" CELLSPACING=0 CELLPADDING=0 ALIGN=CENTER><TR><TD>Quote, originally posted by slammedef06 &raquo;</TD></TR><TR><TD CLASS="quote">anyone? how can we get sound from the portable dvd player through the car speakers?</TD></TR></TABLE>If you get sound out of the DVD when you use headphones and you plug into tha AUX input of the Pioneer it should work, have you tried turning the vol. up on the DVD? 94
Old Mar 31, 2005 | 05:55 PM
Default Re: Installed Portable DVD Player in 95 si but no volume? PLEASE HELP! (fcm)
yes, i have volume all the way up on the dvd player and the deck volume at like 20 and it plays really low with a schreeching sound, i'm gonna check my wiring again just to confirm.
Old Mar 31, 2005 | 06:59 PM
audioroach's Avatar
<TABLE WIDTH="90%" CELLSPACING=0 CELLPADDING=0 ALIGN=CENTER><TR><TD>Quote, originally posted by fcm &raquo;</TD></TR><TR><TD CLASS="quote">If you get sound out of the DVD when you use headphones and you plug into tha AUX input of the Pioneer it should work, have you tried turning the vol. up on the DVD? 94</TD></TR></TABLE>
True...but it also depends on the quality of the unit. I did a similar set up with some
whack low buck jobby of a player and i just could not get sound above a whisper.
(even with the headphones only it was bad). I wish them luck.
Old Apr 1, 2005 | 01:17 PM
fcm's Avatar
fcm
Old Fart
Default Re: Installed Portable DVD Player in 95 si but no volume? PLEASE HELP! (audioroach)
<TABLE WIDTH="90%" CELLSPACING=0 CELLPADDING=0 ALIGN=CENTER><TR><TD>Quote, originally posted by audioroach &raquo;</TD></TR><TR><TD CLASS="quote">
(even with the headphones only it was bad). I wish them luck.</TD></TR></TABLE>I have run into the crappy sound when using the headphone outputs, [all the time] and evan low output when useing the line out, but never low output when useing headphone output, and I'm not sure why that would be, if there is enough sig./power to drive the headphones, why not the AUX. input? 94
Old Apr 2, 2005 | 09:02 PM
so does anyone know why we would be getting low to no sound from plugging the portable dvd player into the head unit? (Headphone side in 'audio' rca's in red and white a/v jacks on back of deck) thanks again!
Old Apr 4, 2005 | 08:20 AM
I have my dvd player plugged into the auxillary and i can turn off the sound on my pioneer deck by turning it all the way down but i cannot make it louder the sound only stays at one level once you try to turn it up. It does come out of the car speakers though but only on the right side I have no clue what the problem is but i think it might be the fact that i need a better head unit??? I am not for sure though?
emooheo
Audio / Security / Video
Feb 28, 2010 07:17 PM
MelissaC
May 17, 2006 12:21 PM
DrunkNRacer
Apr 27, 2005 07:25 AM
pwrofdrm
Jun 4, 2004 05:22 AM
civicboy95
May 26, 2004 11:51 AM
