Mini Me PM6 and OBD0 question
Old Mar 31, 2005 | 06:22 AM
froger's Avatar
Default Mini Me PM6 and OBD0 question
I know i should buy a P28 and OBD1 conversion but if stick with my stock ECU and OBD0 what would I have I need to do the swap if i chose this path?
Old Mar 31, 2005 | 09:03 AM
Rywire's Avatar
Default Re: Mini Me PM6 and OBD0 question (froger)
An rpm switch for vtec... I would just go obd1
Old Mar 31, 2005 | 09:08 AM
EP3_05's Avatar
You would need something to engage VTEC like an rpm switch or a VAFC. I always say run the engine how it was supposed to be run. OBD1
Old Mar 31, 2005 | 11:53 AM
ALLMOTORCRX20's Avatar
You will also need a vtec distributor. You dont need an rpm switch or something to engage vtec if your getting a p28, just wire up the vtec solenoid and pressure to the conversion harness.
Old Mar 31, 2005 | 12:19 PM
mellon's Avatar
Default Re: Mini Me PM6 and OBD0 question (ALLMOTORCRX20)
You need to chip your pm6 with p28 fuel maps and use a dizzy from an a6.
Old Mar 31, 2005 | 02:02 PM
ppfalcon's Avatar
xenocron, can chip you computer to run the vtec and run any air/fuel/ignition maps you want... look for him on forced induction classifieds or check out his web site..
Old Apr 1, 2005 | 12:50 PM
xenocron's Avatar
Default Re: Mini Me PM6 and OBD0 question (ppfalcon)
You now have the capability to use a PM6 and the A/C clutch relay pin/circuit to throw 12v to the VTEC solenoid and activate VTEC at a user defined RPM.
PGMFI.org
turboedit.org
Old Apr 6, 2005 | 04:58 PM
teal_civic_mobile's Avatar
Default Re: Mini Me PM6 and OBD0 question (xenocron)
i was also thinking for that swap putting a 12v relay off of my adjustable tach. so when the shiift light comes on the vtec will engage.
Old Apr 6, 2005 | 05:15 PM
Magick211's Avatar
Default Re: Mini Me PM6 and OBD0 question (teal_civic_mobile)
turboedit ownz p28 fuel maps on pm6, and a/c clutch relay engaging vtec
Old Apr 7, 2005 | 08:52 AM
shauniewalnuts's Avatar
Default Re: Mini Me PM6 and OBD0 question (Magick211)
turboedit
Old Apr 7, 2005 | 10:36 AM
CRXDrew's Avatar
I'm using a Field Controller now, but should switch over to using TurboEdit soon. Might aswell since I'm using turboedit for my turbo
Old Apr 7, 2005 | 11:08 AM
CPT.PANDA's Avatar
iam doing th esame thing. if i use the pm6 how would i wire up my vafc
Old Apr 7, 2005 | 11:41 AM
xenocron's Avatar
Default Re: (jedi_139)
<TABLE WIDTH="90%" CELLSPACING=0 CELLPADDING=0 ALIGN=CENTER><TR><TD>Quote, originally posted by jedi_139 &raquo;</TD></TR><TR><TD CLASS="quote">iam doing th esame thing. if i use the pm6 how would i wire up my vafc</TD></TR></TABLE>
If you use a PM6 and TurboEdit you can sell the VAFC
matt90
16
Apr 12, 2011 10:20 PM
iphatcrxi
Nov 30, 2004 11:11 PM
90honda4gn
Jan 18, 2004 12:05 PM
JDMHatch101
Dec 23, 2003 05:47 AM
91sleeper
10
Sep 8, 2003 08:24 PM
