What do you think it might be
Old Mar 31, 2005 | 01:41 AM
ebpda9's Avatar
Cpt Rice
Default What do you think it might be
I have a 92 Integra LS with approx 134k miles on it. I noticed that the car is lacking power lately, and it tops out at 90-95mph. I just found out that the cylinders #2 and #3 have about 150psi and 1 and 4 are at around 180. Also a weird thing is that the car is not running rough at all at idle, and the idle is pretty normal. Do you think it could be the timing belt ? Never been done.
Old Mar 31, 2005 | 05:24 AM
Racermech's Avatar
Default Re: What do you think it might be (ebpda9)
You compression numbers are pretty low, so that will hurt the performance.
You need to change the timng belt. This is supposed to be done at 90k. If this belt was to break (which they do) you can run the risk of destroying some valves and maybe hurt other parts. It is not a pretty thing when the belt snaps!
Old Apr 3, 2005 | 02:25 PM
ebpda9's Avatar
Cpt Rice
yeah, i looked into replacing the timing belt because the thrads are coming out of it, and it's 1" too big. should i replace the adjuster too ?
Old Apr 3, 2005 | 04:30 PM
97tegGS's Avatar
Yes. Replace the adjust too. When you change something always replace corresponding parts.
IE: Brakes. If one rotor is bad always change both sides.
Don't do something 1/2 assed
95dc2gsr
Apr 23, 2007 05:50 PM
96civ06
Jul 4, 2006 08:28 PM
EJ1 wilcox
18
Apr 8, 2006 01:55 PM
dunkd
May 27, 2005 07:48 PM
BLITZ
Oct 2, 2001 06:36 AM
