what is the diff between obd0 and obd1/2 dizzys?!!?
i am putting a y8 head on my rex using the a6 bottom, and using a p28 ecu. i have my stock a6 distributor and i know it bolts on to the y8, but its obd0. so im wondering is it just the wiring thats different, or are there sensors inside that differ also? jw cause if i can i want to use that distributor instead of buying a diff one? anyone know for sure?
I know for sure that the wiring is different and I know for sure that some of the insides are different. I think the shaft is different, and some other components.
ok yes the wiring is diff, that]s obvious, but wires aint **** when you got some wirecutters and electrical tape =D. if i use my a6 dizzy what will be wrong? timing? im trying to find someone who has attempted this, i already searched. anyone?
you CANT make them work, they work totaly different
thing is the obd0 ecu's read different things from the distro then the obd1 ecu's
hence making it impossible to rig up a obd1 distro with a obd0 ecu
lilsicsoul
Jan 23, 2009 03:52 PM
