drivedhaft ?
Old Mar 30, 2005 | 04:13 PM
cambopheonix56's Avatar
Default drivedhaft ?
I am looking at buying this accord (98 4 dr lx 5-speed 105k miles) and the guy told me that the driveshaft/axelshaft was broken. it is still driveable and everything. but my question is, how hard is it to brake one of these? Did he go into a ditch or something? Or do they just go out for no reason?
Thanks
Modified by cambopheonix56 at 8:11 PM 3/30/2005
Old Mar 31, 2005 | 04:30 AM
G-MO's Avatar
It could be actually broken but more likely than not the cv joints are bad. What are the symptoms which lead him to believe they are broken?
Old Mar 31, 2005 | 07:28 AM
Default Re: (G-MO)
i am not sure he says it just makes a clicking noise. I drove it a short distance (1 block or so) and I didnt hear anything tho.
Old Apr 1, 2005 | 09:42 PM
G-MO's Avatar
clicking is an indication of bad cv joints. Axles are cheap. Might be a good chance to get a deal. How much is he selling it for?
Old Apr 2, 2005 | 12:16 PM
Default Re: (G-MO)
4400 fixed and 4200 as is
Old Apr 4, 2005 | 04:55 AM
JimBlake's Avatar
Default Re: (cambopheonix56)
If you like to work on your own car, a new (rebuilt) axle is less than $200. If you wanna pay a mechanic to put it in, check around to see if it'll cost you more than $200. If you don't even change your own oil, this isn't a good first-job for you.
Then you're only left with the risk that it might turn into a bigger job. Like maybe bad balljoints along with the bad axle.
Don't run away from the car because of this. But maybe pay a mechanic to look at it with you?
Nathan007
Transmission & Drivetrain
Apr 27, 2010 04:49 PM
b1221
Nov 25, 2008 04:48 AM
scabbs
Sep 13, 2007 07:10 AM
rcc80
Apr 20, 2005 04:20 PM
nuc79
Nov 19, 2003 01:44 PM
