jdm 4-1 and o2 sensor question
Old Jan 26, 2002 | 10:49 PM
Jmm0056's Avatar
Default jdm 4-1 and o2 sensor question
does the jdm 4-1 header affect the stock 02 sensors in the obdII cars, if i wanted to run the jdm 4-1 and a test pipe how could i trick the o2 sensors or would i have to buy an obdI conversion
Old Jan 26, 2002 | 10:54 PM
B2FiNiTY's Avatar
Default Re: jdm 4-1 and o2 sensor question (Jmm0056)
The testpipe will set it off. But the JDM 4-1 won't.
Old Jan 26, 2002 | 11:03 PM
Jmm0056's Avatar
Default Re: jdm 4-1 and o2 sensor question (B2FiNiTY)
ok cool, so if the test pipe will set it off is there a way to trick the ecu or would i need to convert to obdI, or what about a carsound cat i've read that they make an obdII application, how much different would the testpipe be from the carsound cat?
Old Jan 26, 2002 | 11:21 PM
Cosworth's Avatar
testpipe and carsound cat both produces results that are within 1-2hp of each other. I would personally get a high-flow cat to reduce the emission. try http://www.ipsracing.com or SMSP on this for a bolt-on carsound cat for your car.
Old Jan 27, 2002 | 05:31 AM
B2FiNiTY's Avatar
I would get a carsound cat instead of the testpipe. More environment friendly, cop friendly, everything friendly. It's not worth the extra HP unless your doing drag or road racing.
Old Jan 27, 2002 | 05:47 AM
Jason's Avatar
I had a test pipe and decided to go w/ a carsound cat and I really couldn't tell a difference between the two. Not worth the hassles of a test pipe IMO...
boarderfatty
Jun 5, 2015 11:26 AM
slvrCD7accord
Mar 29, 2010 07:06 AM
Raven_Accord
Jul 23, 2007 03:54 PM
#26Type-R
Apr 9, 2004 10:14 AM
Striker
Sep 7, 2001 11:50 AM
