KYB AGX shock settings...
Old Jan 26, 2002 | 10:36 PM
Duck Sauce's Avatar
Default KYB AGX shock settings...
What setting do you guys use for the street and for the track with KYB AGX's? I was thinking about using "1" in the rear. And "2" for the front. On the street. Any input would be appreciated.
Old Jan 27, 2002 | 12:17 AM
GSRdriver's Avatar
Default Re: KYB AGX shock settings... (www.s4-mtm.com)
I have it set for 3 front, 2 rear for daily driving.
Old Jan 27, 2002 | 12:25 AM
Duck Sauce's Avatar
Default Re: KYB AGX shock settings... (GSRdriver)
That sounds like a pretty good setup. Let me ask you...did your KYB AGX shocks come with the adjustment dials? I got mine today, but they only came with a small bag with a screwdriver and nuts inside.
Old Jan 27, 2002 | 12:55 AM
vteg's Avatar
New User
The ones with the ***** are for a different model. The integra AGX's have the screw driver and small slot. BTW, I am normally set to 1/1 or 2/2 depending on my mood. This is with sportlines.
Old Jan 27, 2002 | 01:11 AM
is3oo's Avatar
Default Re: KYB AGX shock settings... (vteg)
You guys set it pretty soft. I have my front set at 4 and rear at 5. It's nice and stiff without any bounce, handles really good too.
Old Jan 27, 2002 | 04:53 AM
Vu's Avatar
Vu
Default Re: KYB AGX shock settings... (KPxRyDa)
4 and 5? Is this for an Integra? Mines only have 4f/4r.
Oh, and I put mines to 2f/1r. This setting makes my car ride smoother. 1f/2r or 2f/3r for better steering response and 2/2 for better steering response(not as much as the 1f/2r or 2f/r) while maintaining some smoothness. And I have the Eibach Pro-Kit.
Old Jan 27, 2002 | 09:09 AM
Malice's Avatar
New User
since when do kyb's go up to 5?!!
mine are set at 3 all around.
Old Jan 27, 2002 | 09:52 AM
neo1z's Avatar
Default Re: KYB AGX shock settings... (MaliceGSR)
yea im doin 3 all around too -- and u cant have 5
Old Jan 27, 2002 | 12:37 PM
is3oo's Avatar
Default Re: KYB AGX shock settings... (neo1z)
I own a 2000 Civic so it might be different from the Integras. And arent you suppose to have the rear stiffer than the front for a reason? I can't remember why but someone told me that you were suppose to.
Old Jan 27, 2002 | 12:57 PM
Duck Sauce's Avatar
Rear stiffer than the front creates more oversteer.
Old Jan 27, 2002 | 01:10 PM
is3oo's Avatar
More oversteer? Is that a good thing or bad thing? What exactly does that mean? I thought having the front stiffer than the rear is going to create more oversteer.
Old Jan 27, 2002 | 01:36 PM
BoM's Avatar
BoM
2 F and 3 Rear
2 in front lets my 400lb/in sportline springs not to kill me.
3 will help my shifting feel smoother, because of less bounce to the rear and the
back springs aren't that stiff.
Old Jan 27, 2002 | 02:13 PM
Stephen's Avatar
Default Re: KYB AGX shock settings... (BoM)
There really isn't a "right" setting. Everyone's car is different and you should use the combination that YOU prefer. Generally, most people have the rears set a little stiffer than the front, but you'll find people who have them set really stiff or at the lightest setting. It's really up to you. Go out in a big empty parking lot and do crazy turns, lane changes, and swerves. There will be a setting that you'll like best both for comfort and for over/understeer tendencies...use that one.
Old Jan 27, 2002 | 03:29 PM
InfamousRS's Avatar
Default Re: KYB AGX shock settings... (Stephen)
Im going to put my KYBs on Tuesday if my new rear shock stud and bushing gets here in time. Anyways, I have stock struts with Ground Control right now. Will adding the struts make a big difference steering wise over the stock struts?
Zaraki
Suspension & Brakes
Apr 15, 2012 02:56 PM
say bye to my B18
Suspension & Brakes
Apr 14, 2008 06:49 PM
dtrtw
May 22, 2005 11:31 AM
RussHondaCRX
Jan 8, 2005 01:34 PM
akeldama
Dec 30, 2002 09:49 PM
